My DeltaD3H (DIY Delta printer)
My Duet controlled machine
3.0k
    What I think you need to include in your start gcode is:
    T0 ; select tool 0
    M140 S[bed_temperature] ; set bed temperature
    M104 S[extruder0_temperature] ; set extruder temperature
    M116 ; wait for temperatures to be reached
      EasyTarget
      @DannerD3H:
      My printer always makes a short pause of 1-2 seconds between the first and second layer. does anyone know why this is? (The fans start on the third layer).
      If the temperature changes (first layer hotter than others) then maybe this is another forced pause until the head has cooled to the new temp?
      PS: Lovely printer, the pop out electronics bay makes me jealous..
      Disaster? The original Printeye is dying with RRF 3.5 (M208 depreciated).
      PrintPy2024 to the rescue!
      MicroPython based; with simple wiring and and no custom PCB.
        DannerD3H
        Thank you easy target!
        But don't be jealous.. It seemed like a good idea on the drawing but in reality it is not! It makes proper wire management near impossible as all wires have to be at least 30 cm to long to be able to pull out the tray.. I will most likely ditch it and mount the board permanently instead.
        I have a constant temperature all the way so shouldn't be the case.. Will look closely on the g-code tomorrow to see if I can figure out whether it's a slicer or firmware thing..
        Dc42, if I do that, won't I then have to change something in the start code to use my second nozzle?
        If I ever have to change values on the start code, then I would rather turn on the machine manually first.. But would be cool if starting a print automatically would send the m80 command before executing any of the print file…
          number40fan
          You could always edit the .gcode in a text editor and put the M80 in front of everything. Little time consuming, but should get the job done.
            I have often thought that slicers should support 2 sets of start gcode: one to execute right at the start, and one after the slicer has generated the temperature-setting code before the print starts.
              DannerD3H
              Yes but the post processing of the g-codes are exactly what i want to avoid..
              DC42, yes either that or at least a setting so that the slicer would automatically include the m80 command as the first command..
              Is this something that can be implemented in the Duet web interface? Could it be implemented that every time you start a print, the web interface would send a M80, like when i manually press the ATX on button?
              I n´know it may seem like a silly small thing, but it would just be a nayz feature i think..
                I guess there could be a start.g macro run when you start printing a file from SD card.
                  DannerD3H
                  Is this something that is already possible or ?
                    DannerD3H
                    I finally got to make some prints this weekend. I think this could become a really good printer, but i still have a few issues..
                    This thread is covering my two biggest issues: https://www.duet3d.com/forum/thread.php?pid=37203#p37203
                      @DannerD3H:
                      Not yet, but I will consider it for the next 1.21RC.
                        DannerD3H
                        Cool! 🙂
                        23 out of 24
