Z weird sound and sobbing movement
I have start to have a strange issue on the Z motor.
It has start to do this weird sound and start to sobbing when i changed the confing.g for increase the motor current, X, Y, E0 from 1000mA to 1500mA and the Z motor from 600mA to 1000mA because all the nema17 have 2A rated current.
When i try to move the Z+ or Z- from the web interface it goes only down (it rotates in the same direction).
This is the confing.g with the increased the motor current:; v6 ; Increased motor current. It was M906 X1000 Y1000 Z600 E1000 ;********************************** ; Communication and general ;********************************** M111 S0 ; Debug off M550 PLak_D-Bot_CoreXY ; Machine name (P + anything you like) M551 Preprap ; Machine password (used for FTP connections) M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED ; MAC Address - If you have more than one Duet on your network, they must all have different MAC addresses, so change the last digits M552 S1 ; Enable WiFi M587 S"TP-LINK_422E42" P"31851213" ; Configure access point M586 P0 S1 ; Enable HTTP M586 P1 S0 ; Disable FTP M586 P2 S0 ; Disable Telnet M555 P2 ; Set output to look like Marlin ;M575 P1 B57600 S1 ; Comms parameters for PanelDue ;********************************** ; Machine configuration ;********************************** M667 S1 ; set CoreXY mode M569 P0 S1 ; X motor runs forwards M569 P1 S1 ; Y motor runs forwards M569 P2 S0 ; Z Drive 2 goes forwards M569 P3 S1 ; E Drive 3 goes forwards M574 X1 Y2 Z1 S0 ; set endstop configuration (X1 is at MIN end. Y2 is at MAX end. (active low switch= S0) M350 X16 Y16 Z16 E16 I1 ; Set 16x microstepping with interpolation M92 X80 Y80 Z800 ; Set axis steps/mm. Check that the printer really move as much as you tell it. Not more and not less. M92 E99.5:99.5 ; Set extruder steps/mm. Change this to match your extruder. http://www.instructables.com/id/How-to-calibrate-the-Extruder-on-your-3d-Printer/?ALLSTEPS M906 X1500 Y1500 Z1000 E1500 ; Set motor currents (mA). Increase if motor is to weak. Lower if motor gets too hot. 800-1000 is good for most. M201 X1500 Y1500 Z300 E4000 ; Accelerations (mm/s^2). The acceleration, speed and jerk is a setting you can alter to try making the printer to print as nice as possible.. M203 X15000 Y15000 Z300 E1500 ; Maximum speeds (mm/min) M566 X600 Y600 Z24 E300 ; Maximum jerk speeds mm/minute M208 X290 Y290 Z300 ; set axis maxima (adjust to suit your machine) M208 X0 Y0 Z0 S1 ; set axis minima (adjust to make X=0 and Y=0 the edges of the bed) G21 ; Work in millimetres G90 ; Send absolute coordinates... M83 ; ...but relative extruder moves ;********************************** ; Z probe ;********************************** M558 P5 I0 R0.4 F330 X0 Y0 Z1 ; Digital Z probe, also used for homing the Z axis G31 X0 Y0 Z-0.1 P100 ; Set the probe height ;********************************** ; Thermistors and heaters ;********************************** M140 H-1 ; Disable heated bed M305 P1 T100000 B3950 R4700 ; Thermistors data M570 S120 ;Increase to allow extra heating time if needed M307 H1 A551.2 C137.8 D3.7 B0 ; Data from auto tune PID ;********************************** ; Fans ;********************************** M106 P0 T45 H1 ; thermostatic mode for fan 0 at temp 45 degrees. Fan turns on when H1(extruder 1) is above 45 degrees. M106 P1 T45 H1 ; thermostatic mode for fan 1 at temp 45 degrees. Fan turns on when H1(extruder 1) is above 45 degrees. ;********************************** ; Tool definition ;********************************** M563 P0 D0 H1 ; Define tool 0 G10 P0 S0 R0 ; Set tool 0 operating and standby temperatures M556 S78 X0 Y0 Z0 ; Axis compensation here M208 S1 Z-0.2 ; set minimum Z M912 P0 S4.4 ; Calibration CPU temp M501 ; Load Config-Override.g that is created using M500 T0 ; select first hot end ;********************************** ;END OF CONFIG.G ;**********************************
It can be the board or a motor fail (maybe the cable)?
I have uploaded the old version and it has continued do it.
I have moved the board to look if there was some black zone but i don't see nothing.
I have tried again but it has stop to do it as you can see in the video (i have sewed the two video with and without the weird suond).
I think it's the Z cables but why both motor do it and not just one?
What do you think? -
That could either mean that the leadscrew is binding, or that only one phase of the Z motor is getting energised. So with power off, check that the leadscrews can rotate freely. Then check for continuity of both motor phases of both motors.
I don't see as M584 command in your config.g so I presume you have the 2 Z motors plugged into the 2 Z motor connectors. Those connectors are wires in series. So a bad connection or cable will affect both motors.
Ok thank you, each motor can freely rotate so i will check the cable and the motor phase with a multimeter, i hope to find something so i can be sure to have solved it.
Yes there are 2 Z motor connected in series.
For now thank you for the help -
For now it seam it works. I have soldered the cable extension of one z motor (before it used a dupont connector), the other is near the duet so it hasn't an extension cable.
