Corner LEDs not working
Smart effector for delta printers
4.8k
    mfoltz
    by the way this incident also finally induced me to buy a rework station with temp control and retiring my old radio shack dual wattage soldering iron.
      DjDemonD
      Hi I think I have probably broken my LEDs as I changed from a 12v hotend heater to a 24v one and did not remove the jumper, they did work for quite a while then stopped working.
      If R8 is the problem, I will attempt to fix it, what resistor should I use?
      www.precisionpiezo.co.uk
        R8 is 140R 0.33W. The schematic is at https://github.com/T3P3/SmartEffector/blob/master/SmartEffector/SmartEffector_v1.3/SmartEffector_Schematic_v1.3.pdf.
          DjDemonD
          Thanks David.
            DjDemonD
            Okay so, I ordered a new Smarteffector PCB and swapped it out.
            Rebuilt it with the new PCB (LED jumper OFF this time - 24v) and it works fine.
            But on taking a look at the old one, the R8 resistor looks a little toasty but still reads 140Kohm.
            Maybe it's just not very well soldered?
            NB it's worth stating that I am running my smart effector 3 corner LEDs by connecting the hotend fan connector on the smart effector to the heater in parallel as I now have watercooling and the hotend fan isn't wired up anymore, I needed the two cores in my wiring loom for a thermistor for the heatsink. The PWM to the LEDs shouldn't be a problem should it?
              PWM to the LEDs is OK. As you were previously running the LEDs well above their normal current, perhaps one of them has blown? Let me know if you need a replacement.
                DjDemonD
                Thanks David, I bought another piezo effector pcb, it was my fault they blew, I should have taken the jumper off. I can replace or possibly just resolder the resistor and press the broken one into service elsewhere. I'll check the leds. Hope you had a nice Christmas.
                  @DjDemonD:
                  I meant a replacement LED so that you can mend the old one.
                    DjDemonD
                    Okay thanks will let you know.
                      TYPPA Albert Einstein
                      The 3 white corner led on / off is possible , or light ever time when printing ?
                      Thanks
                      I have no special talent. I am only passionately curious.
                      -Albert Einstein
                        The corner LEDs should illuminate when the hot end fan is powered, if you have the wiring polarity correct.
                          Ok thanks for response DC42,
                          It is boring to always see the LEDs ON, especially at night with long prints. There is no possibility to switch them on / off with a command. Thanks again
                          -Albert Einstein
