    New firmware 1.21RC1 available
    Firmware installation
    24
    71
    10.2k
      There are some new bugs in G29 bed probing in firmware 1.21RC1. I will fix them in the next RC.
      • DocTruckerundefined
        DocTrucker
        Just to clarify if I see a RepRapFirmware.bin file in the release folder it is safe to assume it runs on the Duet v0.6?
        Saw some notes on the 1.20 that this was the last release that you planned for v0.6 / v0.8.5 boards other than 1.20.x bug fixes (such as the 1.20.1RC)?
          Version 1.20.1 got turned into 1.21 because I added some new features. It will be available for the older Duets.
            DocTrucker
            Ah ok, that makes sense. Thanks for the explanation.
            To save me bothering you in the future if there is a RepRapFirmware.bin in a release folder then it is safe to upload onto the v0.6?
              Yes.
              • okerchoundefined
                okercho
                @dc42:
                Hi David, What is this bug related to? I'm having some issues with my bed levelling that is driving me nuts, but I think in my case is a mechanical problem (I've bought a new rods to discard the issue, hopefully I will get them by the end of this week).
                Cheers
                Okercho
                Custom Prusa i3 Hephestos with Duet Wi-Fi
                E3d V6 with Bondtech BMG DirectDrive and PrecisionPiezo Sensor
                Rebuilding Hypercube Evolution
                  The known issues are:
                  • G92 on a delta causes a square height map to be displayed
                  • The new multi tap facility doesn't work with G92
                  • okerchoundefined
                    okercho
                    @dc42:
                    Mechanical issue is still winning the raffle then xD
                    Okercho
                    • Captain_squndefined
                      Captain_sq
                      @dc42:
                      Do you mean G29 or G92?
                      Custom made Kossel Mini - Duet WiFi / Modded Tronxy X5S - Duet WiFi / Prusa i3 MKIII
                      Embedded systems designer, RC Pilot, maker and Gadget-o-holic
                        Captain_sq
                        This evening my Duet 0.6 quit midprint due to a software reset. Diagnostics points to the Network loop. I'm running with fixed IP address.
                        [[language]]
                        M122
                        Used output buffers: 2 of 32 (10 max)
                        RepRapFirmware for Duet version 1.21RC1 running on Duet 0.6
                        Static ram used: 44836
                        Dynamic ram used: 40972
                        Recycled dynamic ram: 208
                        Stack ram used: 1192 current, 4316 maximum
                        Never used ram: 7972
                        Last reset 00:00:16 ago, cause: software
                        Last software reset at 2018-02-01 22:59, reason: Stuck in spin loop, spinning module Network, available RAM 5496 bytes (slot 1)
                        Software reset code 0x6041 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0000080f, BFAR 0xe000ed38, SP 0x20087cd4
                        Stack: 000c0f57 0000000a fffffff9 00000000 7f7f8000 0000000f 0000000a 01010101 000a89f9 000a89f8 81000000 000000be 00000004 000babb1 000ac38f 0000003a 00000001 00000006 2007a9e0 20087d4e 2007ab18 20087d90 20087d48 00000027
                        Error status: 0
                        Free file entries: 10
                        SD card 0 detected, interface speed: 21.0MBytes/sec
                        SD card longest block write time: 0.0ms
                        MCU temperature: min 27.5, current 28.5, max 28.7
                        Date/time: 2018-02-01 22:59:43
                        Slowest main loop (seconds): 0.004105; fastest: 0.000100
                        MaxReps: 0, StepErrors: 0, LaErrors: 0, FreeDm: 100, MinFreeDm 100, MaxWait: 0ms, Underruns: 0, 0
                        Bed compensation in use: mesh
                        Bed heaters = 0, chamberHeaters = -1 -1
                        Heater 1 is on, I-accum = 0.0
                        Segments left: 0
                        Movement lock held by null
                        http is idle in state(s) 0
                        telnet is idle in state(s) 0
                        file is idle in state(s) 0
                        serial is idle in state(s) 0
                        aux is idle in state(s) 0
                        daemon is idle in state(s) 0
                        queue is idle in state(s) 0
                        Code queue is empty.
                        === Network ===
                        Free connections: 15 of 16
                        Free transactions: 23 of 24
                        Locked: 1, state: 4, listening: 0x20071bf0, 0x20071bd4, 0x0
                        • robmundefined
                          robm
                          for the filament monitor, m591 r-1:-1 or similar gives 'allowed movement 2147483647% to 2147483647%' for the probe result - which makes sense to me but is probably not desirable. This is on P3 the rotating magnet filament monitor.
                          Is there a new way to enter the calibration mode?
                          thanks
                          Rob.
                            @Captain_sq:
                            On my list to look at.
                              @robm:
                              thanks
                              Rob.
                              The parameters for filament monitors have been changed in firmware 1.21. See https://duet3d.com/wiki/G-code#M591:_Configure_filament_sensing. However, I haven't tested the rotating magnet sensor with firmware 1.21RC yet.
                              • robmundefined
                                robm
                                @dc42:
                                Thanks, I saw that - but don't see anything in the 1.21 section at all re: calibration mode other than that the 'data will be collected even when filament monitoring is disabled'.
                                Current print with R-1:-1 is generating calibration data so seems to be working and apparently -1 still puts it into calibration mode 🙂
                                thanks,
                                Rob.
                                • robmundefined
                                  robm
                                  Also on the report message for the P3 monitor, it seems to be truncated at the end:
                                  Duet3D rotating magnet filament monitor on endstop input 3, disabled, sensitivity 28.80mm/rev, allowed movement 2147483647% to 2147483647%, check every 3.0mm, current position 298.5, measured sensitivity 26.29mm/rev, measured minimum 3%, maximum 6% over 6
                                  From other messages I am guessing that is over 6xx mm extruded.
                                  Otherwise 1.21RC1 working beautifully on my DIY Prusa i3 variant.
                                  Cheers,
                                  Rob.
                                  • totalitarianundefined
                                    totalitarian
                                    @dc42:
                                    I'll probably change the next RC firmware version to print a warning but take the average of all readings, if the maximum count was reached without being within the tolerance.
                                    Looking forward to that!
                                    • andjan1964undefined
                                      andjan1964
                                      FW: 1.21RC1
                                      WiFi: 1.21RC1
                                      Web: 1.20
                                      Hello dc42 🙂
                                      I have the 1.21RC1 firmware, but i had the problem with the 1.20 also
                                      When i "uppload", or put "directly" a big gcode ( 64mb) to the sd card i get kicked out of the webgui. ( and when i reconnect i see that gcode is "loading" the gcode. And it is a * in the beginning of the filename. and get kicked out again.
                                      I have to delete the gcode from the sd card to get into the webgui, so i not are beeing kicked out.
                                      What can this be ?
                                      Jan Erik
                                        @robm:
                                        @dc42:
                                        thanks,
                                        Rob.
                                        Because calibration data is now always collected, there is no longer a separate calibration mode. Instead there is the S parameter to determine whether the output of the filament monitor is checked or not.
                                        • BMMalundefined
                                          BMMal
                                          I just noticed that I'm not getting time estimates based on layer times nor the actual layer times anymore. Using 1.21RC1 on a Duet Ethernet.
                                          I'm also seeing an issue where the Duet Ethernet becomes very slow after completing a print. Moves are executed at the speed commanded, but the time between commands is very long, almost a minute. Here is the diagnostics from Pronterface when it is in such a state.
                                          [[language]]
                                          Used output buffers: 1 of 32 (16 max)
                                          RepRapFirmware for Duet Ethernet version 1.21RC1 running on Duet Ethernet 1.02 or later + DueX5
                                          Board ID: 08DDM-9FAM2-LW4SD-6JTDL-3S86R-KJW3X
                                          Static ram used: 11992
                                          Dynamic ram used: 100496
                                          Recycled dynamic ram: 2200
                                          Stack ram used: 3568 current, 8440 maximum
                                          Never used ram: 7944
                                          Last reset 00:37:26 ago, cause: software
                                          Last software reset at 2018-02-03 10:13, reason: User, spinning module GCodes, available RAM 7952 bytes (slot 2)
                                          Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0041f000, BFAR 0xe000ed38, SP 0xffffffff
                                          Error status: 0
                                          [ERROR] Error status: 0
                                          Free file entries: 7
                                          MCU temperature: min 27.1, current 27.4, max 31.0
                                          Supply voltage: min 24.2, current 24.5, max 24.7, under voltage events: 0, over voltage events: 0
                                          Driver 0: standstill, SG min/max 0/777
                                          Driver 1: standstill, SG min/max 0/801
                                          Driver 2: standstill, SG min/max 0/1023
                                          Driver 3: standstill, SG min/max 0/80
                                          Driver 5: standstill, SG min/max not available
                                          Driver 6: standstill, SG min/max not available
                                          Driver 7: standstill, SG min/max not available
                                          Expansion motor(s) stall indication: yes
                                          Date/time: 2018-02-03 10:51:11
                                          Slowest main loop (seconds): 0.006912; fastest: 0.000057
                                          MaxReps: 4, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 154, MaxWait: 43644ms, Underruns: 0, 0
                                          Scheduled moves: 635, completed moves: 635
                                          Bed compensation in use: none
                                          Heater 0 is on, I-accum = 0.0
                                          Heater 3 is on, I-accum = 0.7
                                          Segments left: 0
                                          Stack records: 4 allocated, 1 in use
                                          Movement lock held by file
                                          file is doing "M116 P2" in state(s) 0 8
                                          serial is ready with "M122" in state(s) 0
                                          === Network ===
                                          State: 5
                                          HTTP sessions: 1 of 8
                                          Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                                          === Filament sensors ===
                                          Extruder 0 sensor: ok
                                          Extruder 2 sensor: ok
                                          >>> m122
                                          SENDING:M122
                                          Done printing file
                                          Finished printing file 0:/gcodes/20mmTestCube_repaired.gcode, print time was 0h 19m
                                          Used output buffers: 3 of 32 (16 max)
                                          Dynamic ram used
                                          : 100536
                                          Recycled dynamic ram: 2160
                                          Last reset 00:52:51 ago, cause: software
                                          So
                                          Error status: 0
                                          Free file entries: 8
                                          SD card longest block write time: 162.5ms
                                          MCU temperature: m
                                          in 26.7, current 30.1, max 32.1
                                          Supply voltage: min 24.2, current 24.5, max 24.6, under voltage events: 0, over voltage events: 0
                                          Driver 0: standstill, SG min/max 0/819
                                          Driver 1: standstill, SG min/max 0/812
                                          Driver 2: standstill, SG min/max 0/685
                                          Driver 3:
                                          Driver 5: standstill, SG min/max 0/1023
                                          available
                                          Date/time: 2018-02-03 11:06:32
                                          Slowest main loop (seconds): 4.127969; fastest: 0.000066
                                          reeDm 159, MaxWait: 121006ms, Underruns: 0, 0
                                          Segments left: 0
                                          Stack records: 4 allocated, 0 in use
                                          daemon is
                                           idle in state(s) 0
                                          === Network ===
                                          State: 5
                                          Extruder 0 senso
                                          r: ok
                                          Duet Ethernet - Most likely the most recent Edge firmware
                                          Duet X5
                                          7" Panel Due V2
                                          Cartesian, 4 Nozzles with Flex3Drives, Heated Chamber, Simple Switch Filament Sensing
                                            Thanks for you report.
                                            Regarding the printer becoming very slow, I have one other report of this, also on a Duet Ethernet. Next time it happens, please use M111 to enable GCodes, Move and DDA debugging. Then send a movement command. It will echo the gcode, then the move details, then do the move. What I am interested in is where the delay occurs.
