    New firmware 1.21RC1 available
    Firmware installation
    24
    71
    10.0k
    • timcurtis67undefined
      timcurtis67
      I ran my printer for a good 30+ hrs over the weekend after the upgrade and didn't run into any bugs or issues.
      The only thing I think could be happening is slower uploads when I load gcode files? Maybe its my imagination but it seems like the upload speeds are half as fast now? I thought I was seeing 700+ speeds but now 400 is the fastest I have seen.
      1. I'll try resetting my router tonight.
      2. I can revert back to 1.20 to make sure but I'm really happy with this version so far.
      Great work dc42! Thank you.
      • nytundefined
        nyt
        @dc42:
        @nyt:
        I've been noticing some oddities with bed leveling, even before this release.
        I run compensation, and average level is above 0, run it again, it's below, run it again, it's above, etc. It's like it's using old values every time it runs. I tracked this down and fixed it with G29 S2 at the top of bed.g, but shouldn't bed leveling disregard old values anyway?
        Please post your bed.g file.
        Just added the G29 S2 which fixed it…
        G29 S2 ; clear height map
        M376 H10 ; correction taper after 10mm
        M557 X10:394 Y4:390 S55:52
        G28 ; home
        G1 X0 Y0 ; move to 0,0
        M400 ; wait for move to complete
        G29 ; probe bed
        G1 Z5 ; position
        • DaveAundefined
          DaveA
          @Jackal:
          I have just updated from 1.20 to 1.21RC1 and not sure why the mesh bed compensation shows a rectangular bed instead of a circular bed for my delta. I didn't change my config.g, maybe I missed something that I should change?
          I have M558 P1 R0.4 X0 Y0 Z0 H1.5 F100 T3000 I0 in my config.g and M557 R100 S15 in my bed.g
          Just noticed the same thing. When I do a G29 it probes the bed using my correct delta geometry but when it brings up the heightmap it is shown as a rectangle.
          There are also some real "flyers" near the border of the delta area. Dropped back to 1.20 and the delta shape is back and the flyers are gone.
          Is this intentional?
            There are some new bugs in G29 bed probing in firmware 1.21RC1. I will fix them in the next RC.
            • DocTruckerundefined
              DocTrucker
              Just to clarify if I see a RepRapFirmware.bin file in the release folder it is safe to assume it runs on the Duet v0.6?
              Saw some notes on the 1.20 that this was the last release that you planned for v0.6 / v0.8.5 boards other than 1.20.x bug fixes (such as the 1.20.1RC)?
                Version 1.20.1 got turned into 1.21 because I added some new features. It will be available for the older Duets.
                  DocTrucker
                  Ah ok, that makes sense. Thanks for the explanation.
                  To save me bothering you in the future if there is a RepRapFirmware.bin in a release folder then it is safe to upload onto the v0.6?
                    Yes.
                    • okerchoundefined
                      okercho
                      @dc42:
                      Hi David, What is this bug related to? I'm having some issues with my bed levelling that is driving me nuts, but I think in my case is a mechanical problem (I've bought a new rods to discard the issue, hopefully I will get them by the end of this week).
                      Cheers
                      Okercho
                      Custom Prusa i3 Hephestos with Duet Wi-Fi
                      E3d V6 with Bondtech BMG DirectDrive and PrecisionPiezo Sensor
                      Rebuilding Hypercube Evolution
                        The known issues are:
                        • G92 on a delta causes a square height map to be displayed
                        • The new multi tap facility doesn't work with G92
                        • okerchoundefined
                          okercho
                          @dc42:
                          Mechanical issue is still winning the raffle then xD
                          Okercho
                          • Captain_squndefined
                            Captain_sq
                            @dc42:
                            Do you mean G29 or G92?
                            Custom made Kossel Mini - Duet WiFi / Modded Tronxy X5S - Duet WiFi / Prusa i3 MKIII
                            Embedded systems designer, RC Pilot, maker and Gadget-o-holic
                              Captain_sq
                              This evening my Duet 0.6 quit midprint due to a software reset. Diagnostics points to the Network loop. I'm running with fixed IP address.
                              [[language]]
                              M122
                              Used output buffers: 2 of 32 (10 max)
                              RepRapFirmware for Duet version 1.21RC1 running on Duet 0.6
                              Static ram used: 44836
                              Dynamic ram used: 40972
                              Recycled dynamic ram: 208
                              Stack ram used: 1192 current, 4316 maximum
                              Never used ram: 7972
                              Last reset 00:00:16 ago, cause: software
                              Last software reset at 2018-02-01 22:59, reason: Stuck in spin loop, spinning module Network, available RAM 5496 bytes (slot 1)
                              Software reset code 0x6041 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0000080f, BFAR 0xe000ed38, SP 0x20087cd4
                              Stack: 000c0f57 0000000a fffffff9 00000000 7f7f8000 0000000f 0000000a 01010101 000a89f9 000a89f8 81000000 000000be 00000004 000babb1 000ac38f 0000003a 00000001 00000006 2007a9e0 20087d4e 2007ab18 20087d90 20087d48 00000027
                              Error status: 0
                              Free file entries: 10
                              SD card 0 detected, interface speed: 21.0MBytes/sec
                              SD card longest block write time: 0.0ms
                              MCU temperature: min 27.5, current 28.5, max 28.7
                              Date/time: 2018-02-01 22:59:43
                              Slowest main loop (seconds): 0.004105; fastest: 0.000100
                              MaxReps: 0, StepErrors: 0, LaErrors: 0, FreeDm: 100, MinFreeDm 100, MaxWait: 0ms, Underruns: 0, 0
                              Bed compensation in use: mesh
                              Bed heaters = 0, chamberHeaters = -1 -1
                              Heater 1 is on, I-accum = 0.0
                              Segments left: 0
                              Movement lock held by null
                              http is idle in state(s) 0
                              telnet is idle in state(s) 0
                              file is idle in state(s) 0
                              serial is idle in state(s) 0
                              aux is idle in state(s) 0
                              daemon is idle in state(s) 0
                              queue is idle in state(s) 0
                              Code queue is empty.
                              === Network ===
                              Free connections: 15 of 16
                              Free transactions: 23 of 24
                              Locked: 1, state: 4, listening: 0x20071bf0, 0x20071bd4, 0x0
                              • robmundefined
                                robm
                                for the filament monitor, m591 r-1:-1 or similar gives 'allowed movement 2147483647% to 2147483647%' for the probe result - which makes sense to me but is probably not desirable. This is on P3 the rotating magnet filament monitor.
                                Is there a new way to enter the calibration mode?
                                thanks
                                Rob.
                                  @Captain_sq:
                                  On my list to look at.
                                    @robm:
                                    thanks
                                    Rob.
                                    The parameters for filament monitors have been changed in firmware 1.21. See https://duet3d.com/wiki/G-code#M591:_Configure_filament_sensing. However, I haven't tested the rotating magnet sensor with firmware 1.21RC yet.
                                    • robmundefined
                                      robm
                                      @dc42:
                                      Thanks, I saw that - but don't see anything in the 1.21 section at all re: calibration mode other than that the 'data will be collected even when filament monitoring is disabled'.
                                      Current print with R-1:-1 is generating calibration data so seems to be working and apparently -1 still puts it into calibration mode πŸ™‚
                                      thanks,
                                      Rob.
                                      • robmundefined
                                        robm
                                        Also on the report message for the P3 monitor, it seems to be truncated at the end:
                                        Duet3D rotating magnet filament monitor on endstop input 3, disabled, sensitivity 28.80mm/rev, allowed movement 2147483647% to 2147483647%, check every 3.0mm, current position 298.5, measured sensitivity 26.29mm/rev, measured minimum 3%, maximum 6% over 6
                                        From other messages I am guessing that is over 6xx mm extruded.
                                        Otherwise 1.21RC1 working beautifully on my DIY Prusa i3 variant.
                                        Cheers,
                                        Rob.
                                        • totalitarianundefined
                                          totalitarian
                                          @dc42:
                                          I'll probably change the next RC firmware version to print a warning but take the average of all readings, if the maximum count was reached without being within the tolerance.
                                          Looking forward to that!
                                          • andjan1964undefined
                                            andjan1964
                                            FW: 1.21RC1
                                            WiFi: 1.21RC1
                                            Web: 1.20
                                            Hello dc42 πŸ™‚
                                            I have the 1.21RC1 firmware, but i had the problem with the 1.20 also
                                            When i "uppload", or put "directly" a big gcode ( 64mb) to the sd card i get kicked out of the webgui. ( and when i reconnect i see that gcode is "loading" the gcode. And it is a * in the beginning of the filename. and get kicked out again.
                                            I have to delete the gcode from the sd card to get into the webgui, so i not are beeing kicked out.
                                            What can this be ?
                                            Jan Erik
