    How to tune Stall Detection?
    7.2k
      Stall detection is only enabled when printing a GCode file. It's not really possible to test it any other way, because you need the variety of moves that you get in a print to test it properly.
      The mapping of axes to drivers is determined by the M584 command. Send M584 with no parameters to show the existing parameters.
      If your Z axis never trigger stall detection, it probably means that your Z axis speed is configured such the the back emf of the motor is greater than the driver supply voltage at that speed. See https://duet3d.com/wiki/Choosing_stepper_motors#How_to_work_out_the_power_supply_voltage_you_need (there is a link to a spreadsheet at the end).
      • GaRv3undefined
        GaRv3
        So this means, Z is simply to fast?
          Use the link in my previous post to work out whether Z is too fast for stall detection to work, or not.
          • GaRv3undefined
            GaRv3
            Unfortunately I do not know all the required information because there is no chart with all specifications available for my stepper motors. These are Anet 42SHDC3025-24B motors.
            Phase inductance is the one that is missing.
            I entered all values I know (left phase inductance as it was) and got these results:
            [c]Speed at which torque starts to drop (mm/sec), low slip angle 22,3
            Step pulse frequency at this speed and x16 microstepping 8,9
            Speed at which torque starts to drop (mm/sec), high slip angle 29,7
            Step pulse frequency at this speed and x16 microstepping 11,9
            [/c]
            So the maximum speed for stall detection should be 22,3 mm/s, right?
            My Z axis speed is 16.7mm/s but I never got a false stall detection with M915 Z S-10 F0 R1.
            Is this possible? I would like to make sure it works.
              You really do need the phase inductance. To estimate it, search a good range of stepper motors (e.g. the ones at stepperonline.com) for another Nema 17 motor with the same length and a similar phase resistance and rated current.
              • GaRv3undefined
                GaRv3
                Well I tried to find similar stepper motors or other sources for the required information. After several hours I gave up now. I wrote the Anet support an email but to be honest, I do net expect to get a useful answer.
                So I could reduce the speed and try to find a speed where I get false stall reports, reduce the speed even more (additional -2mm/s or so) and tune the S value again. Would this work to give me precise stall detection?
                • GaRv3undefined
                  GaRv3
                  What I did now is:
                  I switched to using two stepper drivers (Z and E1) for my Z axis.
                  I added axes U and V for Z1 and Z2. I zero them when Z is homed so homing does not throw errors.
                  Changed [c]M915 Z S-10 F0 R1[/c] to [c]M915 P2:4 S-10 F0 R1[/c] just to be sure.
                  What I expected:
                  Using two drivers instead of one with the motors cinnected in series should double the maximum speed for stall detection. Is this correct?
                  The result:
                  Even at the very low speed of 5mm/s no false stall detections occur.
                  I am stuck now 😕
                  Edit:
                  Now I wrote a gcode script that moves Z up and down with 5mm/s over and over again.
                  No stalls detected.
                  When I reduce the current of the motors to 20mA, it stopps moving up (obviously), but still no stalls are detected.
                  M950 S was -50 during this test!
                  • GaRv3undefined
                    GaRv3
                    Well, no other suggestions?
                    I need to make this work!
                      Are you definitely running 1.20 or 1.21RC series firmware, on a Duet WiFi or Duet Ethernet?
                      • GaRv3undefined
                        GaRv3
                        Sure!
                          What are your Z steps/mm?
                          • GaRv3undefined
                            GaRv3
                            It's 400 steps/mm
                              From comparing other motors, I estimate the inductance of that motor to be about 8 to 10mH. What maximum Z speed at full torque does that give?
                              • GaRv3undefined
                                GaRv3
                                I am not 100% sure, if all the other values I have are correct.
                                I took them from this site: http://www.mytechnologie.de/2017/05/22/projekt-3d-drucker-die-motoren/
                                I suppose by "maximum Z speed at full torque" you mean "Speed at which torque starts to drop (mm/sec), high slip angle".
                                For 8mH this gives me 32,7mm/s and for 10mH it is 27,9mm/s.
                                • GaRv3undefined
                                  GaRv3
                                  No additional suggestions?
                                  This feature was one of the main reasons for buying the Duet 😕
                                    Is it just the Z motor that you can't get stall detection working on? Does it work on the X and Y motors? How about U?
                                    • GaRv3undefined
                                      GaRv3
                                      It works on X and Y. I tuned the values until I got no more false detections. S22 seems to be the value to go on these axes.
                                      I tried [c]M915 Z S-50 F0 R1[/c] and [c]M915 P2:4 S-50 F0 R1[/c] for Z but never got stall detections on drives other than 0 and 1 (X and Y).
                                        I have added this to my list of pending investigations. I should get to it before the end of this coming week.
                                        • GaRv3undefined
                                          GaRv3
                                          Great, thank you!
                                          • GaRv3undefined
                                            GaRv3
                                            Any news on this already?
