    Wifi Help
    • Mike72undefined
      Mike72
      Pretty new user with wifi board upgraded latest firmware, and Panel Due 3.0, ver 1.17. I just updated firmware and having trouble getting wifi connected.
      SENDING:M587
      Remembered networks:
      3DPRINT IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0
      On my panel I get Http is enabled on port 80, FTP is disabled TELNET is disabled, WIFI module started.
      WIFI reported error, no known networks found.
      Have sent my ssid and pw with M587
      and I get
      M552
      SENDING:M552
      WiFi module is idle
      Not sure where to go from here..
        Please check the following:
        1. Your router is broadcasting its SSID, not hiding it;
        2. Your router's SSID on its 2.4GHz transmissions is exactly "3DPRINT". SSIDs are case-sensitive.
        3. There is a reasonably good WiFi signal strength where the Duet is located.
