    Firmware 1.21 release candidate 2 now available
    Firmware installation
    22
    81
    11.2k
    • hurzhurzundefined
      hurzhurz
      I think there might be a problem with the new BLTouch probe type together with multi-touch Z probing, where it does retract but not re-deploy between the multiple probings for one point.
      I have also opened an issue on github about this while I was waiting for my forum account: https://github.com/dc42/RepRapFirmware/issues/160
      hurzhurz created this issue in dc42/RepRapFirmware
      closed 1.21RC2 / M558: new probe type P9/BLTouch, deploy/retract problem with multi-touch #160
      • MSquaredundefined
        MSquared
        While I am not affected by most of the use cases that this release was designed to address, I can report that I ran two back to back 10+ hours print yesterday with no issues at all.
        The web control interface and file uploads seem to be much faster and more responsive on this release, 1.21RC1 seemed quite slow.
        Looking good!
        • JohnOCFIIundefined
          JohnOCFII
          @dc42:
          I've just made this available at https://github.com/dc42/RepRapFirmware/tree/dev/EdgeRelease/1.21RC2. See https://github.com/dc42/RepRapFirmware/blob/dev/WHATS_NEW.md for the changes and what you need to know before upgrading.
          Question on the G29 fix:
          Fixed problems with G29 bed probing that were introduced in 1.21RC1
          On a Delta, after completing G32 calibration followed by, what appears to be, a successful G29, I've added G29 S1 into my bed.g file. It seems to work fine, and helped with a first layer issue in one area of my bed.
          After I install RC2 (or later) will I need to re-do the G29, or if i'm satisfied with my current results, can I continue to use it as is?
          John
            You should not need to rerun G29 when you upgrade, unless you are upgrading from a really old version - the height map format changed a while back, AFAIR between 1.18 and 1.19.
              JohnOCFII
              @dc42:
              Thanks. Since I ran that G29 with 1.21RC1, I'll consider myself in good shape.
              • Edkirkundefined
                Edkirk
                In a previous post I believe you mentioned ending updates because new hardware is in progress. Did I misread the post or can I expect something new from Duet?
                Thanks, Ed
                • peirofundefined
                  peirof
                  David…
                  Can you give details of new hardware?
                    The reason I intend to cease updating firmware for the Duet 06/085 (also RADDS and Alligator) after release 1.21 is that I am about to change RRF for the Duet WiFi/Ethernet to use a real time operating system (RTOS), and the SAM3X8E based boards don't have enough RAM to support RTOS.
                      A few issues with this release have come to light:
                      • The new bltouch probe support doesn't work properly if you enable the multi-tap function, because it fails to deploy the probe before the second tap
                      • The multi-tap function only implements the recovery delay before the first tap at each probe point, instead of before each tap
                      • Support for the Duet3D rotating magnet filament sensor is not working
                      • joestefanoundefined
                        joestefano
                        I renamed the .bin file for my Ethernet board. It seems to upload but the version on DWC does not reflect the change. M115 shows 1.20. It uploaded to my 2) WIFI boards fine
                          @joestefano:
                          It sounds that the upgrade failed. Are you certain that you got the name right? Use the System Editor page of DWC to check.
                          • kazolarundefined
                            kazolar
                            there is no Duet Ethernet build for this version…RC1 yes, not RC2
                            • kazolarundefined
                              kazolar
                              @kazolar:
                              OK, I see what you did – you combined ethernet and wifi builds -- I renamed the Wifi bin to DuetEthernetFirmware.bin and it worked
                                joestefano
                                DuetEthernetFirmware.bin confirmed on DWC system editor. It copied to the config file and I even tried M997 S0. When I click "yes" to update the panel Due flashes briefly but the update does not happen. M115 still shows V1.20 I thought I had installed 1.21 RC1 but that must not have taken either.
                                  Try uploading the new iap4e.bin file first.
                                    joestefano
                                    I tried that. now the board will not start. I removed the SDcard and copied the iap4e and the DuetEthernetFirmware.bin to the card. How do I install the .bin file using the console on the panel due? M997 is for the WIFI.
                                    • kazolarundefined
                                      kazolar
                                      Not sure if this is related to new firmware or existing issue – I've uploaded a large gcode file ~100mb and now duet is stuck with it on loading for all parameters in DWC and DWC then disconnects (ps file is called Part1.gcode) -- nothing special about the name
                                        @joestefano:
                                        M997 S1 is for the WiFi. M997 S0 (or just M997) installs the main firmware.
                                          @kazolar:
                                          Does the disconnection message say that there was no response from the Duet, or something else?
                                          Please put the GCode file on a file sharing site and post a link to it, so that I can try uploading it.
                                          • kazolarundefined
                                            kazolar
                                            I tried a smaller file and it chokes it as well – 67mb this time. I pulled the sd card, and this time just copied it
                                            I'll share both https://www.dropbox.com/sh/7m1eemyx6ofj3hi/AACh0wYFdcqfqlzr8mERoICZa?dl=0
