    Firmware 1.21 release candidate 2 now available
    Firmware installation
    22
    81
    11.2k
    • kazolarundefined
      kazolar
      I tried a smaller file and it chokes it as well – 67mb this time. I pulled the sd card, and this time just copied it
      I'll share both https://www.dropbox.com/sh/7m1eemyx6ofj3hi/AACh0wYFdcqfqlzr8mERoICZa?dl=0
      • kazolarundefined
        kazolar
        I kept getting disconnect messages because duet was busy, then it finally loaded the 67mb file, and I got:
        Error: Cannot read file.
        Error: Failed to read footer from G-Code file "0:/gcodes/Part1V2.gcode"
        • kazolarundefined
          kazolar
          After it finally read it – I started printing it -- and it fell of the network entirely, but the screen said it was printing -- then i disconnected the network cable and plugged it back in, and it came back, and DWC is back and responsive.
            I uploaded your files to one of my printers, and they uploaded OK and are displayed in the file list. However, no object height or filament usage is displayed. The reason according to Notepad++ is that both files contain vast quantities of null characters shortly before the end, within the footer comments region. If these are as S3D generated them, then I suspect a bug in S3D.
            The error message you received suggests to me that you should replace the SD card.
            • kazolarundefined
              kazolar
              I have seen this before with S3D especially with large files. I will try to re-save them – this is a new high speed card. I think the null characters are confusing duet...I'll try to re-save them and upload them.
              • kazolarundefined
                kazolar
                I edited the file and got rid of the nulls, and it got loaded right away. I'll report this bug to S3D. Thanks for checking.
                • k3lagundefined
                  k3lag
                  I updated, changed my probe type to 9, removed my M401s and M402s from bed.g, homez.g and homeall.g. Everything is working as expected on my IDEX cartesian.
                    @k3lag:
                    Thanks for the feedback. Be aware the the multi touch Z probing is not compatible with bltouch in this release.
                    • kazolarundefined
                      kazolar
                      I have a BL touch and have had the probe type set to 5 and was using multi-touch and it works fine, what is the benefit of using type 9?
                        Some bltouch users had the problem of the bltouch extending too soon again after probing.
                        • k3lagundefined
                          k3lag
                          @dc42:
                          @k3lag:
                          I don't use multi touch at this point, but I may check it out at some point in the future. I seem to get pretty good results with my setup without it. Maybe I got lucky and got a pretty consistent bltouch.
                          Larry
                          • nytundefined
                            nyt
                            @dc42:
                            A few issues with this release have come to light:
                            • The new bltouch probe support doesn't work properly if you enable the multi-tap function, because it fails to deploy the probe before the second tap
                            • The multi-tap function only implements the recovery delay before the first tap at each probe point, instead of before each tap
                            • Support for the Duet3D rotating magnet filament sensor is not working
                            Is it possible to get multitap for Z homing?
                            • Gosuundefined
                              Gosu
                              Firmware Name: RepRapFirmware for Duet WiFi and Duet Ethernet
                              Firmware Version: 1.21RC2 (2018-02-15 build 2)
                              WiFi Server Version: 1.21RC2
                              Web Interface Version: 1.20
                              When i upload a file that is named fooprint(2).gcode and want to print the file it will say file does not exist
                              Error: M32: GCode file "0:/gcodes/26mmgauntbaseV2.gcode" not found
                              10:04:14 PMM32 0:/gcodes/26mmgauntbaseV2(2).gcode
                              any chance you might have a look into that?
                                This issue has been raised several times already. It is part of the NIST GCode standard that parenthesis surround comments, therefore they are stripped out. The workaround is to surround the filename in double quotes. The latest beta of PanelDueFirmware already does this, so will the next version of DWC.
                                • Captain_squndefined
                                  Captain_sq
                                  @dc42:
                                  …or use square brackets instead.
                                  Custom made Kossel Mini - Duet WiFi / Modded Tronxy X5S - Duet WiFi / Prusa i3 MKIII
                                  Embedded systems designer, RC Pilot, maker and Gadget-o-holic
                                  • nickpgreundefined
                                    nickpgre
                                    Came here to report.
                                    CoreXY with bltouch and multitouch probing enabled with Probe 5 (P5), prints and everything works fine. Also the web interface feels more responsive.
                                    • BMMalundefined
                                      BMMal
                                      I just installed this RC so I have not yet reached the end of a print with this firmware but it seems that the slowdown issue here: https://www.duet3d.com/forum/thread.php?id=4045#p36659 still persists. I recently noticed that sometimes my machine would enter this state at the beginning of a print as well as consistently at the end (on RC1). It got stuck in this slow state with RC2 at the beginning of the first print I just started.
                                      I expect that it will enter this slow state at the end of the print as well but if not I will be sure to report back.
                                      Duet Ethernet - Most likely the most recent Edge firmware
                                      Duet X5
                                      7" Panel Due V2
                                      Cartesian, 4 Nozzles with Flex3Drives, Heated Chamber, Simple Switch Filament Sensing
                                      • BMMalundefined
                                        BMMal
                                        On RC1, I got 3 of my simple switch filament sensors working, using the following configurations:
                                        T0 M591 D0 P2 C3
                                        T1 unused for now
                                        T2 M591 D2 P2 C5
                                        T3 M591 D3 P2 C5
                                        I am now getting errors that C5 is not acceptable. Is this correct?
                                        With X, Y, and Z endstops connected what are the C numbers that I can use for 4 filament sensors?
                                        If I went to sensor less homing, what would the C numbers be?
                                        Can some C numbers be used with only certain types of sensors (P)?
                                        Does it matter if an expansion board is present?
                                        It looks like the pad printing on the boards and C numbers correspond as follows, correct?
                                        X C0
                                        Y C1
                                        Z C2
                                        E0 C3
                                        E1 C4
                                        E2 C5
                                        E3 C6
                                        E4 C7
                                        E5 C8
                                        E6 C9
                                        Sorry to ask so many questions but I'm having a hard time figuring this out from the wiki: https://duet3d.dozuki.com/Wiki/Gcode#Section_M591_Configure_filament_sensing
                                        Duet X5
                                        7" Panel Due V2
                                          Thanks for spotting this, it will be fixed in RC3.
                                          • BMMalundefined
                                            BMMal
                                            After installing RC1 (at least that is when I noticed), my machine stopped reporting layer times and therefore estimates based on layer time. This issue persists in RC2. My gcodes are generated using KISSlicer. This may have started because I began using Z hop in Kisslicer (an no FW z hop) since it can filter hops out for really short travel moves.
                                            Duet X5
                                            7" Panel Due V2
