    Configurator never creates config.g
    • Lo-Fiundefined
      Lo-Fi
      Hi
      I'm trying to get my Duet Wifi set up, and using the configurator as suggested. I've run through the pages dozens of times, tried different browsers, disabling popup blocker, leaving everything at default, and just about everything I can think of, but I when I get to the end it never seems to have generated config.g. If I click on it, unlike the others which bring up a preview, nothing happens. If I click to download the zip, it sits at "generating" indefinitely.
      What am I missing please?
      Many thanks
        What OS are you using and which browsers have you tried?
        • Lo-Fiundefined
          Lo-Fi
          Hello
          Win10: chrome, Firefox and IE. Chrome and Firefox (latest builds) did as above, IE had a quirk where it wouldn't bring up the WiFi options; only a MAC address field.
          • mloidlundefined
            mloidl
            Hello
            I have the same issue.
            OS: Linux
            Browsers: Chrome and Firefox
            In the java-script console i get the following error:
            ejs.min.js:1 Uncaught SyntaxError: Unexpected token ) while compiling ejs
                at new Function (<anonymous>)
                at Template.compile (ejs.min.js:1)
                at Object.compile (ejs.min.js:1)
                at handleCache (ejs.min.js:1)
                at Object.exports.render (ejs.min.js:1)
                at Object.success (model.js:618)
                at i (jquery-2.2.3.min.js:2)
                at Object.fireWith [as resolveWith] (jquery-2.2.3.min.js:2)
                at z (jquery-2.2.3.min.js:4)
                at XMLHttpRequest. <anonymous>(jquery-2.2.3.min.js:4)</anonymous></anonymous>
            Maybe this helps.
            Best regards
              Thanks, we'll take a look.
              • chrishammundefined
                chrishamm administrators
                Thanks for the report, it is fixed now.
                Duet software engineer
                • Lo-Fiundefined
                  Lo-Fi
                  Thank you for the quick responses and fix, I've not got my Duet up and running. A bit of a learning curve doing the config, but I'm really pleased with it.
