    Mesh Grid Compensation ignored
    1.5k
    • Dakineundefined
      Dakine
      I just completed wiring up my new Duet Wifi to my Maker Select V2. After some effort I was able to get a simple test print to print properly, using the mesh grid compensation. I do not have a Z probe, and so manually ran the mesh using a sheet of paper. This was after several attempts to get it to use MGC, and it not working. I have no real idea what changed, other than "third time's the charm."
      I haven't been able to get mesh compensation to work since. Running M122 produces the below, which says mesh compensation is in use. However, it clearly is not, as the hot end grinds into my glass bed immediately after homing. I've tried adding G29 S1 to my start g-code, but no joy. I've included my start gcode (from Cura), as well as my heightmap.csv.
      I'm sure I'm missing something simple.
      Thanks for any help!
      GCode
      G21 ;metric values
      G90 ;absolute positioning
      M83 ;set extruder to absolute mode
      G29 S1 ;Load Height Map
      M107 ;start with the fan off
      G28 X0 Y0 ;move X/Y to min endstops
      G28 Z0 ;move Z to min endstops
      G1 Z15.0 F9000 ;move the extruder up 15mm
      G92 E0 ;zero the extruded length
      G1 F200 E3 ;extrude 3mm of feed stock
      G92 E0 ;zero the extruded length again
      G1 F9000
      ;Put printing message on LCD screen
      M117 Printing...
      heightmap.csv
      RepRapFirmware height map file v2, mean error 5.600, deviation 0.216
      xmin,xmax,ymin,ymax,radius,xspacing,yspacing,xnum,ynum
      25.00,175.00,25.00,175.00,-1.00,75.00,75.00,3,3
        5.600,  5.400,  5.100
        5.700,  5.600,  5.600
        5.800,  5.800,  5.800
      M122 Diagnostics
      M122
      Used output buffers: 3 of 32 (14 max)
      RepRapFirmware for Duet WiFi version 1.20 running on Duet WiFi 1.0
      Board ID: 08DGM-95BLL-N65TJ-6J1D6-3S86M-90XVM
      Static ram used: 15448
      Dynamic ram used: 98920
      Recycled dynamic ram: 320
      Stack ram used: 1392 current, 4400 maximum
      Never used ram: 11984
      Last reset 00:02:37 ago, cause: power up
      Last software reset at 2018-02-19 23:40, reason: User, spinning module GCodes, available RAM 7944 bytes (slot 0)
      Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0441f000, BFAR 0xe000ed38, SP 0xffffffff
      Error status: 0
      Free file entries: 10
      SD card longest block write time: 0.0ms
      MCU temperature: min 33.8, current 34.2, max 34.4
      Supply voltage: min 12.3, current 12.3, max 12.5, under voltage events: 0, over voltage events: 0
      Date/time: 2018-02-21 15:21:03
      Cache data hit count 601693000
      Slowest main loop (seconds): 0.156814; fastest: 0.000110
      MaxReps: 0, StepErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
      Bed compensation in use: mesh
      Heater 1 is on, I-accum = 0.0
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      Network state is running
      WiFi firmware version 1.20
      WiFi MAC address 2c:3a:e8:0b:28:97
      WiFi Vcc 3.38, reset reason Turned on by main processor
      WiFi flash size 4194304, free heap 16552
      WiFi IP address 192.168.0.123
      WiFi signal strength -40dBm, reconnections 0, sleep mode modem
      HTTP sessions: 1 of 8
      Socket states: 2 0 0 0 0 0 0 0
      Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
      Maker Select v2 : Duet Wifi : Panel Due 7i
        You should not be getting height map errors of 5mm, they should be much smaller than that. Looks like you may not have homed Z before running mesh bed compensation, or else you have the Z speed or acceleration set much too high in config.g.
        • Dakineundefined
          Dakine
          Hi dc42,
          Yeah, I agree, they need to be smaller than that. However I'm not able to adjust the Z endstop any higher without being higher than the bed can go, due to some damage to the printer. The first thing I plan to print is an adjustable Z-limit: https://www.thingiverse.com/thing:1008176. But for now, this is what I'm stuck with. Can the mesh compensation not handle a 5mm offset? the maximum difference between heights is only .9mm, admittedly still too much, but seems like it's well within operating capacity.
          All three axes are homed. My Z is set to 120, and my acceleration is set to 100. These are actually a bit lower than they were on the Melzi board previously I believe.
          Again, I was able to print one test damn near perfectly. But the mesh just isn't loading any more, or is loading inconsistently and I'm getting a string of bad luck.
            What do you have in your Z homing file and in homez.g? If you are using a low end Z endstop switch, you can use a G92 command after the G1 S1 Z command to specify the height at which the endstop triggers. See https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCartesianPrinter#Section_Homing_Z.
            • Dakineundefined
              Dakine
              It looks like I have a G92 Z2.5. If my understanding is correct, this would tell the printer that the current Z position is actually 2.5mm, not 0mm. When adjusting for the mesh it would only lift up by about 2.5mm instead of 5mm, correct? That would seem like it could be part of my issue if that's the case.
              I commented the G92out of the homez.g and homeall.g, and re-ran the mesh compensation just to be safe. It's still digging into the bed however.
              ; homez.g
              ; called to home the Z axis
              ; generated by RepRapFirmware Configuration Tool on Sun Feb 18 2018 21:28:00 GMT-1000 (HST)
              G91               ; relative positioning
              ;G1 Z5 F6000       ; lift Z relative to current position
              G1 S1 Z-185 F1800 ; move Z down until the switch triggers
              G92 Z2.5          ; set Z position to trigger height
              G1 Z5 F100       ; lift Z relative to current position
              G90              ; absolute positioning
                If the homing switch triggers when the nozzle is 2.5mm above the bed, then the G92 Z2.5 command is correct.
                • Dakineundefined
                  Dakine
                  Ok, then it sounds like I don't need that command since the homing switch is hit below the bed surface. This happens because the glass surface doesn't extend to the XYZ home corner, plus the nozzle compresses the bed spring a little when homing Z. Not Ideal, but I can't print my Z-Limit adjuster until the printer prints again.
                  That being the case, if the switch is hit ~5mm below the bed surface, shouldn't the ~5mm mesh grid compensation account for that?
                  • Dakineundefined
                    Dakine
                    Hmm. I think I've somehow worked through this. It looks like my steps/mm micro-stepping commands were off by quite a bit. I've adjusted those and it looks like things are working out now, although I'm sure it's not dialed in just yet.
                    I think removing the errant G92 commands helped as well. I'm not certain why the configurator put them in.
                    Fortunately I've discovered several more issues after trying to print again, so at least I won't be bored tonight!
                    Thanks for the help dc42.
                      If the switch is hit 5mm below the bed surface, you should use G92 Z-5 after the G1 S1 Z command. Change Z-5 to the actual value you measure.
