    Wiring and Setup of a mechanical micro switch for probing
    • pabomanundefined
      paboman
      im unable to understand how to setup the config.g in order to get a normally open z probe to work.
      I want to be able to use the z probe connection header so E0 endstop remains free for filament runout detector later on.
      MODE 5 is the way to go but below , in the documentation, says a microswitch must be connected to E0 thats why im confused
        To use a normally open microswitch connected to the Z probe connector, use P7 and I1 in the M558 command. You must be using firmware 1.20 or later to use P7.
        • DjDemonDundefined
          DjDemonD
          Hi David. If there is room in your busy schedule (not sarcasm) could the new probe modes be documented into the dozuki wiki?
          www.precisionpiezo.co.uk
          • pabomanundefined
            paboman
            what MODE 7 do ? cant find it in the documentation
            I installed 1.20rc2
            • pabomanundefined
              paboman
              tried with P7 Mode but i get "probe already triggered" while on P5 works fine with M558 P5 H35 F600 T6000 I1
              PS How to get notification on a post reply ?
                @paboman:
                I installed 1.20rc2
                1.20 full release has been available for some time, see https://github.com/dc42/RepRapFirmware/releases.
                I have updated the documentation for M558 on the GCodes wiki page.
