    Delta Diagonal Rod length Corrections
    1.2k
    • buzzbyundefined
      buzzby
      Hi Everyone,
      On my Micro make D1 it is printing undersized items. I have been working through this diagonal rod length process https://www.thingiverse.com/thing:1274733. In terms of printing, it is working fine but i am confused as to where i add in the corrections for each rod length. I can change the overall rod length with the M665 command but the process also gives me corrections for each tower and i don't know where they go.
      For example, the results of my printing give me these values to use in the config.
      OUTPUT For Repetier
      Diagonal rod lenght Corr.diagonal A Corr.diagonal B Corr. diagonal C
      238.187 -0.204 0.281 -0.077
      Can anyone help?
        It is generally best to leave the diagonal rod length set to the value you measured. Adjust the tower steps/mm to get the Z scaling right, then recalibrate, then measure the XY scaling and use M579 to correct it.
        • buzzbyundefined
          buzzby
          The documentation says that 579 doesn't work well on a delta
            @buzzby:
            What documentation would that be? M579 was introduced specifically for delta printers, although it works on any architecture.
            • buzzbyundefined
              buzzby
              My bad. Read the documentation too quickly. Thanks for the help I will experiment.
              Do I add a M579 line to my config.g
