    Firmware 1.21 release candidate 2 now available
    Firmware installation
    22
    81
    11.2k
    • kazolarundefined
      kazolar
      My duet is connected to constant 5V power, so it's always "on" – so does it make sense to run disable/enable network at start of each print? Or include those commands in my power off/power on macros? Is it a side effect of it being on all the time?
      • BMMalundefined
        BMMal
        @dc42:
        Thanks. I've had similar reports from a small number of Duet Ethernet users, but not with 1.21RC2. You've confirmed that this issue hasn't gone away in the new combined Duet WiFi/Duet Ethernet firmware.
        If it happens again, please try the following:
        1. See if you can connect to a PC via USB and Pronterface or a terminal emulator and run simple non-movement commands e.g. M115.
        2. If so, send M552 S0 to stop the network interface, then wait for the acknowledgment. See if normal speed is resumed.
        3. If normal speed is resumed, send M552 S1 to start the network interface.
        Alternatively, if you are able to connect DWC you can just send M552 S0 and see if normal speed is resumed. Obviously you will lose the connection, and you will need to restart the network from USB or PanelDue.
        I think you may have missed my comment reporting that this persisted for me on RC2 as well. It is on the previous page of the thread.
        I can also confirm that mine still does this at the end of prints and often when idle.
        Duet Ethernet - Most likely the most recent Edge firmware
        Duet X5
        7" Panel Due V2
        Cartesian, 4 Nozzles with Flex3Drives, Heated Chamber, Simple Switch Filament Sensing
        • resamundefined
          resam
          I just installed firmware RC2 and also the WifiServer RC2. It seems like I'm having FTP issues again.
          [c]wget -r -nH ftp://10.0.0.42/[/c] just hangs at trying to transfer/load [c].listing[/c].
          As soon as I execute wget, DWC gets a request timeout. After a few seconds I can reconnect with DWC, but wget still hangs and I have to kill it.
          M122 doesn't show anything - not even an active FTP socket.
          The console on PanelDue shows the well known message that it (re-) connected to my WiFi, no error message, just that it is connected now.
          Reverting back to WifiServer 1.21RC1 solves it.
            Thanks for the report, added to my list to investigate.
            • JohnOCFIIundefined
              JohnOCFII
              Just as a datapoint - I installed RC2 over RC1 on DuetWiFi and did a quick G32 calibration and test print on my Kossel Mini. All when well.
              • SantiagoMTundefined
                SantiagoMT
                good morning, 5 days ago I updated the duet to 1.21rc2 and for more that I change the config.g the hot bed to pid keeps showing up in bang bang, I do not know what file to play to change it to pid, in 1.20 and 1.19 it could change without problem, what may be happening?
                  The bed heater will run in PID mode if you have a M307 command for it that includes the B0 parameter.
                  • S1lencerundefined
                    S1lencer
                    Currently iam printing a lot of parts over night, i think the funktion of Enable autosleep in DWC does not work correctly if not at all.
                    Came to the Printer in the morning and it had still the printing tempretures on the nozzle an bed.
                    • nytundefined
                      nyt
                      @dc42, here's a video showing the pause problem I reported earlier. The first pause happens when it moves to the right side to start the infill. You can see on the resume it moves back into place, then for some reason moves slowly left, then back into position and continues. I pause again during the infill, and you can see another move to the left and back again, though this one quicker. This is easy for me to reproduce.
                      https://www.youtube.com/watch?v=22Rw0M8L6tI
                      This is my resume.g, nothing fancy.
                      M83 ; relative extruder moves
                      G1 R1 X0 Y0 Z2 F6000 ; move to 2mm above resume point
                      G1 X0 Y0 Z0 R1 ; lower nozzle to resume point
                      G1 E12 F3600 ; undo the retraction from pause.g
                      and this is the resurrect.g file it created
                      ; File "0:/gcodes/8mm socket wrench.gcode" resume print after print paused at 2018-02-25 18:05
                      M140 P0 S115.0
                      G10 P0 S270 R170
                      T0 P0
                      G29 S1
                      M98 Presurrect-prologue.g
                      M106 P0 S0.00
                      M106 P2 S0.00
                      M106 P3 S0.00
                      M106 P4 S0.00
                      M106 P5 S0.00
                      M106 P6 S0.00
                      M106 P7 S0.00
                      M106 P8 S0.00
                      M106 S0.00
                      M116
                      M290 S0.000
                      G92 E0.00000
                      M83
                      M23 0:/gcodes/8mm socket wrench.gcode
                      M26 S288869 P0.000
                      G0 F6000 Z4.799
                      G0 F6000 X223.19 Y198.95
                      G0 F6000 Z2.799
                      G1 F3600.0 P0
                      M24
                        Can you explain exactly what you think is wrong in that sequence? Also I will need the GCode file you were printing so that I can correlate it with the resurrect.g file.
                        • nytundefined
                          nyt
                          @dc42:
                          The nozzle moves to the left after resuming, then back to where it should be. You can see the nozzle drop, then at 13 seconds in the video slowly move left the first time, then back to where it should be, and continue. That move is not correct.
                          Here's the gcode file. I don't know if the resurrect file has anything to do with it, but I didn't notice this behavior before that bit of code was added to the firmware.
                          http://rznt.com/wrench.gcode
                          • nytundefined
                            nyt
                            @dc42, here's a video that shows the issue much better.
                            Instead of moving straight back after the resume, it goes diagonal across the square, then back to the position it should have moved to.
                            It looks like when it resumes, it's inserting the next before the current move.
                            https://www.youtube.com/watch?v=70KkYPV3kDU
                              Thanks, that's much clearer. Can you share the resurrect.g file that was generated, and the original GCode file? The resurrect.g file will give me the exact offset in the GCode file at which the pause occurred.
                              • nytundefined
                                nyt
                                I'll have to recreate it again, have a print running atm and have paused since. I'll recreate and upload it in a little bit.
                                The gcode is pretty simple, just a bunch of this…
                                ; layer 17, Z = 3.400
                                ; inner perimeter
                                M204 P 600
                                G1 X175.600 Y224.400 F18000
                                G1 Z3.400 F1200
                                G1 E0.4000 F3600
                                G1 X175.600 Y175.600 E1.5419 F2700
                                G1 X224.400 Y175.600 E1.5419
                                G1 X224.400 Y224.400 E1.5419
                                G1 X175.600 Y224.400 E1.5419
                                G1 X175.600 Y224.200 F3600
                                ; outer perimeter
                                M204 P 600
                                G1 X175.200 Y224.800 F18000
                                G1 X175.200 Y175.200 E1.5672 F1800
                                G1 X224.800 Y175.200 E1.5672
                                G1 X224.800 Y224.800 E1.5672
                                G1 X175.200 Y224.800 E1.5672
                                G1 E-0.4000 F3600
                                G1 X175.200 Y224.600 F3600
                                G1 Z3.700 F1200
                                • nytundefined
                                  nyt
                                  recreated again, http://rznt.com/resumebug.zip
                                    Thanks. I believe I have identified the problem and fixed it; so please can you test again with 1.21RC3 when I have released it.
                                    • kraegarundefined
                                      kraegar
                                      I scanned and did not see it, sorry if this is working as intended. I use the Z probe for homing Z. With multi-probe enabled, it still only probes once when homing Z. When I run bed.g, it probes twice (or more) as needed, though.
                                      • nytundefined
                                        nyt
                                        I think that's intended, but it'd be nice to have multi tap when homing z
                                          It might be possible already:
                                          • Start with a plain G30 at whatever XY point you want
                                          • Follow it with e.g. G30 X100 Y100 S0 (if that doesn't work, G30 P0 X100 Y100 S0 might)
                                          Warning: I haven't tried this!
                                          • whosrdaddyundefined
                                            whosrdaddy
                                            David, can you explain what behavior we should expect?
                                            Will the second G30 perform multitapping or not? (I tried without P0 but did not multitap)
