    Duet WiFi in access point mode
    Firmware installation
    8.5k
      I'm glad it's working for you. 8 characters is the minimum allowed for WPA. I'll add putting a check on that to the work list, also an option to not broadcast the SSID.
      I recommend you use RRF 1.20beta11 and DWS 1.20beta10 now.
      • KSorensenundefined
        KSorensen
        I updated the firmware, wifi server and web interface to version 1.20. I was able to successfully initiate and utilize the access point mode, nearly flawlessly. When I cut power to the printer and turned it on again, the Duet forgot the settings.
        Is there a way to write these settings to EEPROM, or should they already be saved by using the M589 command?
          The settings are already saved by the M589 command. You can retrieve them (except the password) by sending M598 with no parameters. You should only need to put M552 S2 in config.g to have it always start in access point mode.
            KSorensen
            I have tried the M552 S2 command in config.g by:
            1. changing line 3 in config.g from M552 S1 to M552 S2
            2. changing line 3 in config.g from M552 S1 to M552 S0, then adding M552 S2 immediately after or at the very end
            3. using G4 S120 at the end of the code followed by M552 S2
            Each of these results in the same issue:
            After powering down, On startup the duet broadcasts an open wifi access point named "AI-THINKER_2FBDDD"
            To get my custom access point to initiate, I have to wait about 30-60 seconds after power on, then open a terminal and send M552 S2
            Any suggestions?
              How strange! It's working fine for me, although I am using a later version of DuetWiFiServer. My suggestions:
              1. Upgrade to DuetWiFiServer.bin 1.21RC2. Also upgrade main firmware to 1.21RC2 because I am not certain whether the new WiFi firmware is compatible with the older main firmware.
              2. If that doesn't solve the problem, send M588 S"*" to clear the flash memory, then use M589 to set the access point details again.
              HTH David
                KSorensen
                I upgraded to 1.21RC2 and tried clearing the flash but I am still struggling with the same problem. A simple send from the terminal activates the access point, but it will still not connect on startup.
                How and where in the config.g do you have your M552 S2 command?
                  I have M552 S2 near the beginning, after setting the machine name. It shouldn't matter where because the network is not activated until config.g has been fully processed.
                  I'll review the network startup code.
                  • Skimmyundefined
                    Skimmy
                    Currently running (downloaded today):
                    [[language]]
                    Firmware Version:	1.21 RC2 (2018-02-15 build 2))
                    WiFi Server Version:	1.21 RC2
                    Web Interface Version:	1.20
                    I configured M589 like said here , like so:
                    [[language]]
                    file config.g:
                    ; network
                    M552 S0 ;
                    M589 S"MY_PRINTER" P"psswrd123456" I192.168.2.100 ;  access point
                    M586 P0 S1                      ; Enable HTTP
                    M552 S2
                    But this only works, when I send "M552 S2" AGAIN via console, after the board booted. I did put "M552 S2" into the config.g, but appearently, this doesn't help?! Do I have to put the M552 S2 somewhere else?
                    Before I do send M552 S2 via console, the DUET creates an unsecured network called "AI-THINKER_0AEB5B", which I can connect to, but can not reach the web-interface. After sending M552 S2, the network "MY_PRINTER" is available (and the blue LED on the wifi-module is on) and the "AI-THINKER…" network disappears.
                    my blog: https://www.well-engineered.net
                      What happens if you remove the M552 S0 and M589 commands from config.g? The M589 parameters are saved on the WiFi module so no need to keep resetting them.
                      • Skimmyundefined
                        Skimmy
                        ok, changed config.g to:
                        [[language]]
                        ; network
                        M552 S2                         ; Enable network
                        M586 P1 S0                      ; Disable FTP
                        M586 P2 S0                      ; Disable Telnet
                        Restarted (from the prompt in the webinterface after changing the config). Then:
                        [[language]]
                        SENT: M552
                        READ: WiFi module is idle
                        If I put M552 S1, the Duet connects to my homenetwork, if I put M552 S2, the duet starts the accesspoint (wifi module is providing accesspoint…).
                        But it does not start it on its own after bootup.
                          I don't know if it will help, but please try putting the M586 parameters before the M552. Or omit them, because the default is to enable HTTP only anyway.
                          • Skimmyundefined
                            Skimmy
                            I did remove all M586 commands, but everything is still the same.
                            Is there a way to call a macro automatically after boot up? This way I could force to load a macro with M552 S2 in it after the boot up…
                              Even though I haven't yet been able to reproduce this, I've added it to the list of issues to investigate before the 1.21 firmware release.
                              • Skimmyundefined
                                Skimmy
                                @dc42:
                                ok, thank you.
                                  KSorensen
                                  ^^^ This is the exact same problem I have been having. No matter how I change the config.g, The access point will not start automatically after Boot up. I have to manually enter M552 S2 through the console to turn it on. Once on, though, it has been flawless.
                                  • Skimmyundefined
                                    Skimmy
                                    Ok, i fiddled around this evening and found out, that the accesspoint works EVERY TIME, when using:
                                    8 caps letters for SSID and 8 caps letters for the password. Example:
                                    [[language]]
                                    M589 S"MEINDUET" P"MEINWIFI" I192.168.178.250;
                                    As soon as the SSID contains lowcase-letters or numbers, it doesn't work anymore. Same for the password. And using less or more digits than 8 doesn't work too.
                                      Have you tried firmware 1.21RC3 yet? I made a change that should improve it, see the release notes.
                                      • Skimmyundefined
                                        Skimmy
                                        @dc42:
                                        I updated to RC3 on firmware and webserver, and RC4 on the interface, and a quick test with:
                                        [[language]]
                                        M589 S"test123" P"test123" I192.168.178.250;
                                        didn't work. Back to all capital letters and 8 per parameter and it is functional again.
                                          How did you send the M589 command to the Duet? After sending it, did you send M589 without parameters to confirm that it had stored the right details, including the lowercase characters in the SSID?
                                          The SSID of my delta is Kossel, the password includes lowercase characters, and I can connect to it.
                                          • Skimmyundefined
                                            Skimmy
                                            I did test it via macro.
                                            This did not work:
                                            [[language]]
                                            ; SetNetwork macro to set up access to dummy test Wifi network
                                            M552 S0;
                                            G4 S5;
                                            G4 S5;
                                            M552 S2;
                                            This works everytime:
                                            [[language]]
                                            M552 S0;
                                            G4 S5;
                                            G4 S5;
                                            M552 S2;
                                            Noticed, that since using RC3, changing from M552 S2 over M552 S0 to M552 S1 doesn't work sometimes.
                                            Using the makro:
                                            [[language]]
                                            M552 S0;
                                            G4 S5;
                                            M552 S1;
                                            sometimes results in:
                                            [[language]]
                                            WiFi module  is idle Failed to change WiFi mode (code -7)
                                            executing the macro or M552 S1 again does work in this case.
