    Resume print after color change in vase mode issue
    1.8k
      How do you invoke that macro?
      • mrac1undefined
        mrac1
        Within the post processing in S3D, and this command:
        {REPLACE "; process color2" "M98 P/macros/color change"}
        {REPLACE "; process color3" "M98 P/macros/color change"}
        I rename the processes for the color change accordingly
          I think the problem is no pause command is being issued, so the paused coordinates needed by the G1 R1 commands at the end are undefined.
          • mrac1undefined
            mrac1
            Now I've tried it with M226, but this doesn't solve the problem. But I've seen, the z-height ist correct, it's just to slow and the filament is ozzing out while traveling (takes about 5sec).
            The weird thing is, without vase mode, it works really nice.
              Without vase mode, my guess is that the slicer is inserting a move to the correct XYZ position immediately after that comment you are replacing and the associated tool change.
              • mrac1undefined
                mrac1
                This is the gcode in normal mode:
                G1 X-8.710 Y11.054 E0.0291
                G1 X-9.300 Y10.635 E0.0291
                G1 X-9.623 Y10.357 E0.0171
                G1 X-9.850 Y10.161 F1019
                G1 E-1.6000 F2100
                G1 Z5.250 F15000
                ; layer 21, Z = 5.200
                M104 S215 T0
                M140 S60
                M106 S224
                G1 X-9.855 Y10.156 F18000
                G1 Z5.200 F15000
                G1 E1.6000 F2100
                G1 X-10.158 Y9.854 E0.0172 F1019
                G1 X-10.399 Y9.587 E0.0144
                G1 X-10.808 Y9.069 E0.0265
                and in vase mode:
                G1 X-8.710 Y11.054 Z4.944 E0.0291
                G1 X-9.300 Y10.635 Z4.946 E0.0291
                G1 X-9.850 Y10.161 Z4.948 E0.0291
                M104 S215 T0
                M140 S60
                M106 S224
                G1 X-10.158 Y9.854 Z4.950 E0.0175 F1019
                G1 X-10.399 Y9.587 Z4.951 E0.0144
                G1 X-10.808 Y9.069 Z4.952 E0.0265
                Maybe you find something what's going wrong.
                  So in normal mode you have this:
                  M104 S215 T0
                  M140 S60
                  M106 S224
                  G1 Z5.200 F15000
                  G1 E1.6000 F2100
                  After the tool change it sets XY and then Z to the required position before it does any extrusion. In vase mode it does this:
                  M104 S215 T0
                  M140 S60
                  M106 S224
                  It doesn't reset the position before extruding again.
                  • mrac1undefined
                    mrac1
                    In normal mode, it's the startpoint of the next layer, in vase mode, there ist no startpoint, because there ist no endpoint from the last layer. Any suggestions how I could solve this?
                      I am implementing the G60 command in firmware 1.21RC3. I think using this will solve your problem.
                      • mrac1undefined
                        mrac1
                        Thank you very much David!
                        • mrac1undefined
                          mrac1
                          Unfortunately, nothing has changed. G60 S0 saves the current position and with G1 R0 the nozzle is going back to the saved position. But I do not think that's the problem. The position is simply approached very slowly. And as I said, the strange thing is, it only happens in vase mode. Otherwise the movement is normal fast.
                          From these lines, it is slow:
                          G1 R1 Z50 F6000 ; go to 50mm above position of the last print move
                          G1 R1 ; go back to the last print move
                          Then it goes on normally.
                            G1 R0 does nothing at all because only axes that are mentioned are moved. Use these lines instead:
                            G1 R0 X0 Y0 Z50 F6000
                            G1 R0 X0 Y0 Z0
                            I don't know why you use Z50, I use Z2 for this sort of thing.
                            • mrac1undefined
                              mrac1
                              The 50mm are only for the test so that there is more room for the extruded filament when changing. I'll try your suggestion later, I'm curious if this affects the travel speed.
                              • mrac1undefined
                                mrac1
                                You where right! šŸ™‚ Travel speed is now fast again! Thank you!
