    NPN zprobe Will Not reverse on |1 Switch
    • dmkmediaundefined
      dmkmedia
      I cannot get my NPN sensor to select active low logic level for the Z probe I have followed the instruction
      NPN output normally-open inductive or capacitive sensor
      and I have connected the silicon diode anode of the diode to the E0 STP pin
      when I plug it in the indicator light is off and in machine properties, the endstop hit is showing yes on drive 3 when there is nothing ner but no when I touch the sensor
      Here is my endstop Settings
      [[language]]
      M574 X1 Y2 S1
      M574 Z1 S0
      M558 P4 H5 F120 T6000 |1
      G31 P600 X0 Y0 Z2.5
      M557 X15:185 Y15:260 S20
      https://dmkitservices.com
        1. You need to use I1 (uppercase-letter-i followed by 1) not |1 (vertical-bar 1) as you appear to have done.
        2. Some users have found that they need to use a Schottky diode, not a normal silicon diode.
        • dmkmediaundefined
          dmkmedia
          i seem to have diodes but no Schottky diode. and the amended code won't work
          dam i was hoping to get this finished toda
          • dmkmediaundefined
            dmkmedia
            i have sorted it i have made a retractable switch zprobe
