    Extrusion factor not 'sticking'
    PanelDue
    • benkayundefined
      benkay
      Hey,
      If I try and change the extrusion factor from my PanelDue display, I can change the value and then push "set". The new value % shows for a split second, but then reverts back to the previous value.
      I can confirm the new value has not been applied, as it is not updated in the web interface.
      If I update the extrusion factor from the web interface, then this is immediately reflected on the PanelDue.
      Any ideas why this is the case?
      Tevo Little monster with Duet Wifi and Smart Effector / magball arms upgrades.
      Original Prusa i3 Mk3
        Which PanelDue firmware version are you using, and is it extruder 0 or a different extruder? A bug in this area was fixed recently.
        • benkayundefined
          benkay
          I'm using 1.20beta1 on PanelDue 7…connected by 4 core cable....everything else seems to work perfectly.
          It's Extruder 0.
            Thanks, I've reproduced the problem. I hope to release a new beta today.
            • benkayundefined
              benkay
              Thanks! Saw the firmware release post, will try tonight.
              • benkayundefined
                benkay
                Confirmed fixed with the new PanelDue firmware…thanks David!
