Call end.g when sdcard file completes
Although slicers will automatically add pre and post code, I would like the firmware to automatically call a macro upon completion of the print.
You can create a file called end.g and then call it with the M98 command from your slicer end code.
https://duet3d.dozuki.com/Wiki/GCode#Section_M98_Call_Macro_Subprogram
So add M98 end.g to the slicer end code.
Then add whatever you want to end.g
It already calls stop.g if your file ends with command M0.
Thanks. And thanks. I suspected there must be already a solution.
