    WiFi reported error: no known networks found
    2.9k
    • Quadcellsundefined
      Quadcells
      I am following the steps from here: https://betrue3d.dk/duet-wifi-getting-started/#dlinstall
      but when trying to enable the wifi I get this:
      M552 S1
      SENDING:M552 S1
      Wifi module is idle
      What am I doing wrong?
      /quadcells
      /quadcells
        I assume you are running firmware 1.19 or later. Send M587 with no parameters to the Duet, then check that the network(s) it lists is/are the one(s) you told it about, and that the SSID is exactly right. SSIDs are case-sensitive.
          Quadcells
          Thanks for the reply.
          Did I miss a step?
          M587 returns:
          Remembered networks:
          TNCAP2FCC19
          Well I missed something.
          I did not setup any networks for the DuetWifi.
          I guess I need to configure the Firmware configuration file.
          I should state that this is a new board DuetWifi 1.03.
          I tore down my Delta that I built but never was able to printed with it.
          I decided to replace my controller with a DuetWifi.
          Been reading so much in what little spare time I have to understand the Duet hardware and the Reprap firmware.
          Still learning.
          /quadcells
          /quadcells
            See https://duet3d.dozuki.com/Guide/1.%29+Getting+Connected+to+your+Duet/7.
              Quadcells
              Thank you, looking it over now
              /quadcells
                Quadcells
                dc42,
                Thanks for pointing out that guide to me. It has helped me a ton.
                /quadcells
                /quadcells
