Delta Printer Nozzle height
3.3k
    Billhc83
    This is meant to be manually done once delta calibration is finished.
    Jog the head to the bed until it just grabs a piece of regular paper. Send g92 z0 via pronterface or DWC. Upload and print. I only do this once when I start the machine.
      @Quadcells:
      @dc42:
      Try running auto calibration (G31) after homing and then not homing again before the print starts. So if there is a G28 command in your slicer start gcode, either remove it (and then home and tun calibration manually before printing a file), or put G31 after the G28 line.
      It's best to heat the bed up to temperature and the hot end either up to temperature of most of the way there before running auto calibration.
      This had the same outcome.
      There was a typo in my post, it should have been G32 not G31.
        @Billhc83:
        It should not be necessary to set the height manually using G92, unless the Z probe is not giving consistent results.
          Quadcells
          @dc42:
          @Quadcells:
          @dc42:
          I tried again and the nozzle still digs into the bed.
          With the S3D slicer should the Z setting under Update Machine Definition match what is in the H parameter in the M665
          /quadcells
            The Z setting in the slicer only affects the size of the part it will slice without warning you. Setting it about the same as the M665 H parameter is good.
            Try running auto calibration, then put a sheet of ordinary 80gsm paper on the bed and command the nozzle to X0 Y0 Z0. The nozzle should grip the paper, but not too tightly. If it grips tightly, then that suggests that the Smart Effector is triggering at a height of less than the -0.1mm that you have set in the G31 command. In which case:
            • If the height at X0 Y0 is correct but away from X0Y0 the nozzle digs into the bed, that suggests a calibration problem. What deviation does auto calibration report?
            • Check that you are using the recommended probing speed, F1000 in the M558 command.
            • Are you using the default Smart Effector sensitivity, or have you reduced it?
            • What bed material are you using? With a softer bed the trigger height may be below -0.1mm
            • Check that your G31 command to set the trigger height to -0.1mm is after the M558 command in config.g
            • You can change the G31 trigger height, e.g. using G31 Z-0.2 instead of Z-0.1 will raise the nozzle by 0.1mm.
            HTH David
              Quadcells
              Hi David,
              "- If the height at X0 Y0 is correct but away from X0Y0 the nozzle digs into the bed, that suggests a calibration problem. What deviation does auto calibration report?"
              Deviation before= 1.853 after 1.581
              "- Check that you are using the recommended probing speed, F1000 in the M558 command."
              Yes I am using the recommended probing speed of F1000 in the M558 command.
              "- Are you using the default Smart Effector sensitivity, or have you reduced it?"
              I did not change this parameter.
              "- What bed material are you using? With a softer bed the trigger height may be below -0.1mm"
              The bed is tool plate aluminum 305mm x 305mm x 6mm with a 120v silicone heater attached underneath and a 300mm x 300m x 1mm build platform sticker like this one: https://www.amazon.com/HICTOP-Printing-Surface-Heated-300x300mm/dp/B074QM92S7/ref=sr_1_2?ie=UTF8&qid=1520960475&sr=8-2&keywords=300mm+x+300mm+build+platform+sticker
              "- Check that your G31 command to set the trigger height to -0.1mm is after the M558 command in config.g"
              It is.
              "- You can change the G31 trigger height, e.g. using G31 Z-0.2 instead of Z-0.1 will raise the nozzle by 0.1mm."
              I ran the auto calibration, put a piece of paper down and sent G1 X0 Y0 Z0 via the DWC. The paper was in good. I then used the PanleDue interface controls to move the nozzle in the +Z direction at .5 increments until there was enough space for the paper to be just grabbing the nozzle, Z= +2.5. I added that number to the G31 trigger height which came to -2.6 and changed G31 Z-.1 to Z-2.6.
              I have printed 2 20mm cubes measuring Z=20.01mm X=22.61mm Y=22.65mm and Z=20.01mm X=22.58mm Y=22.62mm.
              The L parameter in M665 is 400.97 which is on the label attached to the arms that I bought from Haydn Huntley.
              Can I leave such a large value in the G31 Z parameter, Is it recommended to not this type of build platform sticker.
              Thanks again for all your help everyone! Not done but I think it is looking promising.
              /quadcells
                I think the problem is that your calibration deviation of 1.581mm is much too high. With a Smart Effector and a good build, you should easily be able to get it below 0.1mm.
                Please check the points at https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer#Section_Make_sure_your_build_is_accurate and see if you can spot anything wrong. Also please post your bed.g file.
                  Quadcells
                  @dc42:
                  Here is the bed.g file, I will have to check my build later, just came in after clearing our 20 inches of snow off the cars and driveway and I am beat.
                  ; bed.g
                  ; called to perform automatic delta calibration via G32
                  ; generated by RepRapFirmware Configuration Tool on Thu Mar 08 2018 15:49:43 GMT-0500 (Eastern Standard Time)
                  G28 ; home all towers
                  ; Probe the bed at 3 peripheral and 0 halfway points, and perform 3-factor auto compensation
                  ; Before running this, you should have set up your Z-probe trigger height to suit your build, in the G31 command in config.g.
                  G30 P0 X0 Y104.9 H0 Z-99999
                  G30 P1 X90.85 Y-52.45 H0 Z-99999
                  G30 P2 X-90.85 Y-52.45 H0 Z-99999
                  G30 P3 X0 Y0 H0 Z-99999 S3
                  ; Use S-1 for measurements only, without calculations. Use S4 for endstop heights and Z-height only. Use S6 for full 6 factors
                  ; If your Z probe has significantly different trigger heights depending on XY position, adjust the H parameters in the G30 commands accordingly. The value of each H parameter should be (trigger height at that XY position) - (trigger height at centre of bed)
                  /quadcells
                    Billhc83
                    @dc42:
                    @Billhc83:
                    I agree but I find lighting at different times of the day can affect the reading slightly. It is just easier for me to eliminate the variable. Although with the baby step function small variances are easily fixed now
                      Dougal1957
                      @Quadcells:
                      @dc42:
                      ; bed.g
                      Your bed.g is probably causing your issue.
                      I would recommend you go to http://www.escher3d.com/pages/wizards/wizardbed.php and generate a ned BED.G File using at least the default probe settings but change the bed size to suit your build and manually edit the last G30 line it spits out to be S8 at the end rather than S6 and try again.
                      HTH Doug
                        Yes, the problem is you are only doing 3-factor calibration, so the delta radius isn't being calibrated - and I suspect your delta radius setting is significantly in error. You should use at least S4, and normally S6 or S8.
                          Quadcells
                          Doug & David,
                          That was it.
                          I ran the bed.g configuration tool at http://www.escher3d.com/pages/wizards/wizardbed.php using S6 total of 16 points.
                          Paste it in my bed.g file and changed G31 trigger height back to Z-0.1.
                          Results for deviation now 0.088
                          Re-printed my 20mm test cube and now it measures X = 20.12, Y = 20.15 , Z = 20.10.
                          So close to what it should be.
                          Thank you!
                          /quadcells
                          24 out of 26
