Your browser does not seem to support JavaScript. As a result, your viewing experience will be diminished, and you have been placed in read-only mode.
Please download a browser that supports JavaScript, or enable it if it's disabled (i.e. NoScript).
What should i use as x/y offset. Distance from nozzle to which point between IR transmitter and receivers?
The sensitive area of the IR sensor is just below the black cylindrical capacitor, about 1mm above the top surface of the PCB.
Cool thanks
