    At job finish - - > email
    Firmware wishlist
    • peirofundefined
      peirof
      One interesting function, is when the print finish, Duet send an email… Or when an error occurs
      • peirofundefined
        peirof
        And more….
        Maybe, send orders, gcodes for email..
        Pe:
        • Calibrate
        • Motors off
        • heaters off /on
        Gcodes, that Duet console, can execute
          If you put command M0 at the end of your slicer end gcode then it will run macro sys/stop.g when the print finishes. if that macro is not found, the firmware turns off the heaters and the motors.
          There is not yet a facility to send an email when a print finishes.
