    Instruction for custom splash screen
    Firmware installation
    2.8k
      Yes, I use copy /b to do this.
        I have added instructions to the readme file at https://github.com/dc42/PanelDueFirmware.
        • timcurtis67undefined
          timcurtis67
          Sweet! Thank you David.
          I have a 7" PanelDue with the 256kb memory chip on a V2 board. Is there a V2 7" no logo.bin version that I can down load or do I have to build my own?
          I mean a PanelDue-v2-7.0-nologo.bin version?
            All the -v2- files are without logo.
              timcurtis67
              @dc42:
              I missed that before. So any for a V2 board versions will have to be built from scratch.
                No, you can use the -v2- files as they are.
                • mrac1undefined
                  mrac1
                  Hi David, there is a little typo in the readme.md:
                  "Run this Windows command to compress the image: bmp2c-escher3d.exe myimage.bmp myimage.bin /b /c"
                  instead of:
                  "Run this Windows command to compress the image: bmp2c-escher3d.exe myimage.bmp myimage.bin -b -c"
                    Thanks, I've corrected it.
                    • pabomanundefined
                      paboman
                      Sorry how to run copy /b file1+file2 targetfile ?
                      Im using Windows + R to open the command terminal then write g:\ copy /b file1+file2 targetfile
                      because my files are in both in drive G but when hitting enter it only open the G:\ folder
                      • pabomanundefined
                        paboman
                        Ok got it, I have to use CMD terminal, navigate to the G drive and then execute the command 😄
