    Snapping Z end stops.
    1.0k
    • Threeveeundefined
      Threevee
      Recently finished installing the duet and testing all the things in my wanhao i3 plus. Homing works great heaters work great and everythings reading correctly - however whenever i start my first print the Z axis comes down too far and snaps off the Z endstop. I have confirmed the Z stop is working correctly and it does home correctly but starting a print just snaps the stop off time and time again. Anybody have any ideas what could be causing this?
        Are you saying that it isn't stopping at the Z endstop; or it is stopping but going a little too far before it stops? Or it stops at the right place, but subsequently the print head moves too low?
        Please post your homeall.g, homez.g and config.g files, and tell us what type of Z endstop or probe you are using for Z homing.
        • Threeveeundefined
          Threevee
          The whole gantry comes down too far and subsequently nozzle and everything else pushes the bed down on its springs. Its a regular microswitch end stop no Z probe as yet.
          ; Configuration file for Duet WiFi (firmware version 1.20 or newer)
          ; generated by RepRapFirmware Configuration Tool on Thu Mar 15 2018 17:14:58 GMT+0000 (GMT)
          G90 ; Send absolute coordinates…
          M550 PWendell ; Set machine name
          M551 P ; Set password
          M552 S1 ; Enable network
          M587 S"" P"" ; Configure access point. You can delete this line once connected
          M586 P0 S1 ; Enable HTTP
          M586 P1 S0 ; Disable FTP
          M586 P2 S0 ; Disable Telnet
          M350 X128 Y128 Z128 E16 I0 ; Configure microstepping without interpolation
          M92 X640 Y640 Z3200 E200 ; Set steps per mm
          M566 X900 Y900 Z12 E120 ; Set maximum instantaneous speed changes (mm/min)
          M203 X12000 Y12000 Z1200 E3000 ; Set maximum speeds (mm/min)
          M201 X1000 Y1000 Z100 E5000 ; Set accelerations (mm/s^2)
          M906 X855 Y855 Z855 E855 I30 ; Set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 X200 Y200 Z180 S0 ; Set axis maxima
          M574 X1 Y1 Z1 S0 ; Set active low endstops
          M558 P0 H5 F120 T6000 ; Set Z probe type to switch and the dive height + speeds
          G31 P500 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
          M557 X25:175 Y25:175 S20 ; Define mesh grid
          M305 P0 T100000 B3988 C0 R4700 ; Set thermistor + ADC parameters for heater 0
          M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
          M106 P0 S0.3 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
          M106 P1 S1 I0 F500 H T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
          M106 P2 S1 I0 F500 H T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
          M563 P0 D0 H1 ; Define tool 0
          ; Automatic power saving
          M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
          T0 ; Select first tool
          • Threeveeundefined
            Threevee
            ; homeall.g
            ; called to home all axes
            G91 ; relative positioning
            G1 Z5 F6000 ; lift Z relative to current position
            G1 S1 X-205 Y-205 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
            G1 S1 X-205 Y-205 F360 ; move slowly to X and Y axis endstops once more (second pass)
            G1 S1 Z-185 F1800 S1 ; move Z down stopping at the endstop
            G90 ; absolute positioning
            G92 Z2.5 ; set new Z position
            ;G1 Z5 F100 ; uncomment this line to lift the nozzle after homing
            • Threeveeundefined
              Threevee
              ; homez.g
              ; called to home the Z axis
              G1 S1 Z-185 F1800 ; move Z down until the switch triggers
              G92 Z0 ; set Z position to trigger height
              ;G91 ; relative positioning
              ;G90 ; absolute positioning
              • Threeveeundefined
                Threevee
                G31 P500 X0 Y0 Z2.5
                I bet this is the problem. Z should be 0 i think
                • Threeveeundefined
                  Threevee
                  @Threevee:
                  G31 P500 X0 Y0 Z2.5
                  Nah that didn't do it.
                    You have this in homeall.g:
                    but this in homez.g:
                    The first tells the firmware (in the G92 command) that your Z homing switch triggers at Z=2.5mm. The second says your Z homing switch triggers at Z=0mm. So at least one of them is wrong. What height does your Z homing switch actually trigger at?
                    • Threeveeundefined
                      Threevee
                      Zero. Thanks for that ill give it a go tonight!
