Static IP [solved]
5.3k
    DjDemonD
    Hi, would anyone care to share the part of their config.g (for a duet wifi) which enables static IP (I'm running 1.21 rc5 but I presume any 1.21 rcx version will work the same).
    I have up until now been running 3 machines with DHCP, and have setup router reservations for them, but wanted to neaten things up.
    Thanks in advance.
    www.precisionpiezo.co.uk
      DjDemonD
      Okay so I solved my own problem. In case it helps here's how I did it.
      I made a file using my pc on the SD card in macros called setnetwork:
      M552 S0 ;stop wifi
      G4 P1000 ;pause
      M587 S"3DP" P"********" I192.168.0.4 J192.168.0.1 K255.255.255.0 ;add my network and IP address,gateway,netmask
      Then changed my config.g networking section to just
      ;networking
      M540 P**************************; MAC Address
      M552 S1 ;start wifi
      -Reinserted the sd card into the duetwifi and hit the reset button
      -Connect the machine by USB and opened console in pronterface.
      -Sent M558 S"*" which forgets all known networks, send it like that the * means all networks
      -Then M98 P/macros/setnetwork
      Then restarted the machine now its IP address is 192.168.0.4 as I wanted it to be.
      (obviously the data in the fields above refers to my network and machine, I have replaced anything sensitive with ***** - I know this is obvious to most, but just in case)
        PlasticMetal
        This is an Ethernet model, but I would think they would be essentially the same.
        ; Communication and general
        M111 S0
        M550 PRostock MAX V2
        M551 Pxxxxxxxxxx
        ;*** If you have more than one Duet on your network, they must all have different MAC addresses, so change the last digits
        M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED ; MAC Address
        M552 S1 ; Turn network on
        ;*** Ethernet networking: Adjust the IP address and gateway in the following 2 lines to suit your network
        M552 P192.168.1.119 ; (0 = DHCP)
        M554 P192.168.1.1 ; Gateway
        M553 P255.255.255.0 ; Netmask
          DjDemonD
          Thanks, so there are several methods.
            The Duet Ethernet and the older Ethernet Duets use M552/554/553 to set the IP address, gateway and netmask because you only need one set. On the Duet WiFi, you may need a different set depending on which WiFi network you connect to. That's why the parameters are included in the M587 command for the Duet WiFi.
              gavatron3000
              Another way is to set the Mac address in the router to have a specific address. I had to do this due to not being able to access the internet through my pi for updates. And it's easy as to do.
              2 out of 6
