    Filament monitor using HC-020K encoder
    Filament Monitor
    7.9k
    • pabomanundefined
      paboman
      On smoothie I use a HC-020K encoder as filament monitor https://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Dtoys-and-games&field-keywords=HC-020K
      Now I am migrating to DUET and wondering if I can still use the same HC-020K encoder to tell the RR firmware if the filament is slipping or not.
      thanks
      smoothie filament monitor wiki:
      http://smoothieware.org/filament-detector
        Judging by the schematic at https://sites.google.com/site/myscratchbooks/home/projects/project-11-infrared-speed-sensing-module it looks like it produces pulses as the filament wheel turns. So you may be able to connect it to a spare endstop input and use M591 with the P7 option to configure it in RRF.
        Unlike the two prototype Duet3D sensors, it does not provide direction information; so although it may be able to tell you when the filament has stopped moving, it probably won't be able to correlate actual movement to commanded movement.
        You may have to reduce the optical interruptor series resistor to make it work reliably on 3.3V power.
        • pabomanundefined
          paboman
          You provide al information I need, thank you!
          As my intention was to use it without modifications I think I will go with your solution for filament sensing.
          When the sensor will be available again in the official duet online shop ?
            I can't say when we will have production filament sensors, because we are still trying to see whether we can get the laser prototypes working as well as the rotating magnet prototypes. So if you already have that other sensor, try it!
            • pabomanundefined
              paboman
              Ok I have wired the sensor to the E0 stop and configured as follow:
              [c]; Filament Monitor HC-020K
              M591 D0 P7 C3 S1 R70:130 L24.8 E3.0 ; Duet3D rotating magnet sensor for extruder drive 0 is connected to E0 endstop input, 7 = pulse-generating, sensorsensitivity 24.8mm.rev, 70% to 130% tolerance, 3mm detection length
              M591 D0 ; display filament sensor parameters for extruder drive 0
              [/c]
              For testing purpose the encoder is temporary mounted to the estruder stepper so I can easily simulate the encoder stop reading
              The L value has not been calculated yet so its 24.8mm/rev for now
              https://youtu.be/skg_SJgsGZk
              Sending M591 D0 I get:
              [c]M591 D0
              Pulse-type filament monitor on endstop input 3, sensitivity 1.00mm/pulse, check every 3.0mm, tolerance 70.0%, no data received[/c]
              What should I do next to test or calibrate it ?
              My idea is to run a print without filament then move away the encoder from the wheel to simulate a filament jamming, I expect it to pause the print.
                To calibrate it, run a print (with filament). Send M591 D0 to get the calibration data. You can do this as it is printing, as often as you want. To restart accumulating calibration data, pause and then resume the print.
                Note, the support for pulse-type filament sensor is experimental. I don't have a sensor of that type, so it is very likely that it doesn't work. If you can provide feedback on any issues you encounter, I may be able to include fixes in the 1.21 firmware release.
                • pabomanundefined
                  paboman
                  Actually I cant run a print with filament because my test setup is like in the video I made https://youtu.be/skg_SJgsGZk
                  but the duet think its reading the filament so should be good for gathering data.
                  • pabomanundefined
                    paboman
                    Progress update:
                    I have changed the tolerance from 70 to 50%
                    As you can see in the new video https://youtu.be/pRrZK0OoPBg I am running a print, E0 stop led is blinking as the encoder send pulses but duet is telling me: No data received.
                    [c]M591 D0
                    Pulse-type filament monitor on endstop input 3, sensitivity 1.00mm/pulse, check every 3.0mm, tolerance 50.0%, no data received[/c]
                      It could be that your sensor pulls the endstop input low enough to light the LED but not low enough to register as low in the processor. Use the Machine Properties tab of DWC to check whether the detected state of that input changes as the wheel rotates and the LED turns on and off.
                      • pabomanundefined
                        paboman
                        In the DWC the E0 is triggered correctly, it change its state from NO to YES as I rotate the encoder wheel
                          Thanks. I found the first bug in support for pulsed filament sensors. Please try the firmware at https://www.dropbox.com/s/iq9pzfaugyfei7x/Duet2CombinedFirmware.bin?dl=0.
                          • pabomanundefined
                            paboman
                            Installed the firmware 1.21RC5+ (2018-03-17 build 1) apparently nothing has changed.
                            Still [c]M591 D0
                            https://youtu.be/nitZGkwWn7s
                            Maybe something wrong with my conf.g ?
                              Did you get that report after the wheel had spun a few times and the LED flashed off and on?
                              • pabomanundefined
                                paboman
                                yes, after 30 min of printing the report is the same
                                  I've rewritten the pulsed filament monitor support based on the code for the rotating magnet sensor, which is know to be working. Also I have changed the configuration parameters to be the same as for the rotating magnet sensor. You are welcome to try it (it's at https://www.dropbox.com/s/iq9pzfaugyfei7x/Duet2CombinedFirmware.bin?dl=0)), but as I haven't had time to test it yet I don't expect it to work.
                                  • pabomanundefined
                                    paboman
                                    I have just upgraded the firmware, should I change something in my config.g ?
                                    Right now i have :
                                    M591 D0 P7 C3 S1 R70:130 L24.8 E3.0 ; Duet3D rotating magnet sensor for extruder drive 0 is connected to E0 endstop input, 7 = pulse-generating, sensorsensitivity 24.8mm.rev, 50% to 130% tolerance, 3mm detection length
                                    M591 D0 ; display filament sensor parameters for extruder drive 0[/c]
                                    • pabomanundefined
                                      paboman
                                      now after the prints begins i get : [c]Extruder 0 reports too little movement[/c]
                                      • pabomanundefined
                                        paboman
                                        Upgraded to:
                                        1.21RC5+ (2018-03-17 build 2)
                                        I have changed my settings in config.g to:
                                        M591 D0 P7 S23.5 C3 R50 E3.0 ; Duet3d sensor for extruder drive 0 is connected to endstop input 3 (E0), S=23.5mm/rev, R=50% error detection tolerance, C=3mm comparison length
                                        Still getting [c]Extruder 0 reports too little movement[/c]
                                        the strange thing is that The S parameters is set to 23.5 while after M591 D0 I get :
                                        [c]M591 D0
                                        Pulse-type filament monitor on endstop input 3, enabled, sensitivity 28.80mm/pulse, allowed movement 50% to 160%, check every 3.0mm, current position 0.0, no calibration data[/c]
                                        the S parameter is 28.8 instead of 23.5
                                        I will be more than happy to send you one HC-020K encoder, just send me the adress to info@3dbnz.com and on Monday UPS will collect the parcel.
                                        in the mean time, thank you
                                        • pabomanundefined
                                          paboman
                                          setting the sensitivity very low to 0.2 makes the print goes thru
                                          then issuing M591 D0
                                          I get [c]Pulse-type filament monitor on endstop input 3, disabled, sensitivity 28.80mm/pulse, allowed movement 20% to 160%, check every 3.0mm, current position 0.0, measured sensitivity 160.73mm/pulse, measured minimum 0%, maximum 2877% over 63648.7mm [/c]
                                          so i set S value to 160 but then i get again:
                                          and the printer go to pause
                                          PS
                                          while the S is 0.2 there is no difference if I remove the sensor from the wheel, the print does not go to pause
                                          Why M591 D0 is telling me [c]disabled[/c] ?
                                            As I said, I brought the parameters into line with the other filament monitors. So S now enables or disables filament monitoring, and L sets the sensitivity. See https://duet3d.dozuki.com/Wiki/Gcode#Section_M591_Configure_filament_sensing.
                                            You will probably need to increase the E parameter.
                                            160mm/pulse sounds far too high. Can you measure it?
