    Duet - no response back
    1.9k
      In YAT go to Terminal -> Settings ->Text Settings. You will find the EOL setting there.
      • mlbuxbaumundefined
        mlbuxbaum
        changed and still no response back from Duet
          mlbuxbaum
          com port was shut down for some reason….changed com port and I can connect now.
          Is = WiFi signal strength -38dBm, reconnections 0, sleep mode modem okay?
            Yes, -38dBm is a very strong signal.
              mlbuxbaum
              cool cuz its at -43 now…....i moved it closer.
              Also with regards to this in the 1.21 RC5 update
              On Cartesian and CoreXY printers, normal G0 and G1 moves are no longer allowed before the corresponding axes have been homed. In particular, if your homex.g, homey.g and homeall.g files raise Z a little at the start and lower it at the end, you will need to add the S2 parameter to those G1 Z moves. Otherwise the G1 Z move will be refused unless Z has already been homed and the homing macro will be terminated.
              would that be like this?
              G1 S2 Z5 F6000 ; lift Z relative to current position
              It was G1 Z5 F6000
              getting errors about homing now, and z axis doesnt stop when endstop is triggered.
              M120
              G91
              G1 Z-1 F6000
              M121
              Error: G0/G1: insufficient axes homed
              Error: Pop(): stack underflow!
                Yes, adding S2 to that G1 Z5 command should fix that.
                1.21RC5 is now out of date because version 1.21 has been released. (RC means Release candidate).
                  mlbuxbaum
                  thank you. Updated the web interface and now to test… still getting errors.
                  7:37:08 AM G28 Z
                  7:37:06 AM G28 Y
                  7:36:58 AM G28 X
                    It sounds that you are still missing some S2 modifiers in your homez.g, homey.g and homeall.g files. If you are using a Z probe to home Z then you need to home X and Y first.
                      mlbuxbaum
                      ; homeall.g
                      ; called to home all axes
                      ; generated by RepRapFirmware Configuration Tool on Fri Feb 16 2018 11:11:03 GMT-0500 (Eastern Standard Time)
                      G91 ; relative positioning
                      G1 S1 X-305 Y-305 F1800 ; move quickly to X or Y endstop and stop there (first pass)
                      G1 S1 X-305 ; home X axis
                      G1 S1 Y-305 ; home Y axis
                      G1 S1 X-305 F360 ; move slowly to X axis endstop once more (second pass)
                      G1 S1 Y-305 ; then move slowly to Y axis endstop
                      G90 ; absolute positioning
                      G1 X-13 Y3 F6000 ; go to first bed probe point and home Z
                      ;G1 Z5 F100 ; uncomment this line to lift the nozzle after homing
                        mlbuxbaum
                        ; homex.g
                        ; called to home the X axis
                        G1 S1 X-305 F1800 ; move quickly to X axis endstop and stop there (first pass)
                        G1 X5 F6000 ; go back a few mm
                        G1 Z-5 F6000 ; lower Z again
                          mlbuxbaum
                          ; homey.g
                          ; called to home the Y axis
                          G1 S1 Y-305 F1800 ; move quickly to Y axis endstop and stop there (first pass)
                          G1 Y5 F6000 ; go back a few mm
                          G1 S1 Y-305 F360 ; move slowly to Y axis endstop once more (second pass)
                            mlbuxbaum
                            ; homez.g
                            ; called to home the Z axis
                            G1 Z5 F6000 ; lift Z relative to current position
                            G1 X-13 Y3 F6000 ; go to first probe point
                            ;G91 ; relative positioning
                            ;G90 ; absolute positioning
                              homeall.g looks ok to me.
                              homex.g needs S2 added to line "G1 Z-5 F6000" because Z is not necessarily homed at that point. Same for homey.g.
                              homez.g looks OK, but you need to home X and Y before running homez.
                                mlbuxbaum
                                thank you
                                  mlbuxbaum
                                  Added the S2 command to those files….
                                  homed x - no error
                                  homed y - no error
                                  homed z and....
                                  G28 Z
                                  however when I use Home All
                                  no errors and homes great
                                  I added S2 to the homez file and seems to work fine now
                                    mlbuxbaum
                                    new issue….
                                    when i load an .stl file and try to print, the connection terminates.
                                      You can't print an STL file directly, you need to slice it first and then upload and print the .gcode file that the slicer generates.
