    Inserting a pause using S3D and my Duet
    1.9k
    • resamundefined
      resam
      I'm using this to pause the print after layer 112 is done, and before it starts layer 113:
      {REPLACE "\n; layer 113," "\nM226\n;layer 113,"}
      • vonGreezlyundefined
        vonGreezly
        @resam:
        I was hoping for something simple like this! but for some reason it doesn't work… do you just put it in the post processing box? or somewhere else?
          vonGreezly
          @mrac1:
          Ok, you need a macro on the duet which controls your filament change. You create this directly via DWC in the macro area. Take my macro out of the thread as inspiration. Name it eg. "ColorChange"
          In S3D use the "Variable Settings Wizard" (Menue "Tools") to generate a second (third… and so on) processes depending on the layer height.
          Rename this process to something like "Color2" (Color3, Color4...) (doubleclick on the process and change the name in the first line of the fff settings)
          In the postprocessing area insert:
          {REPLACE "; process Color2" "M98 P/macros/ColorChange"}
          {REPLACE "; process Color3" "M98 P/macros/ColorChange"}
          {REPLACE "; process Color4" "M98 P/macros/ColorChange"}
          Color2 is the name of the process
          M98 is the Gcode to call the macro
          /macros/ is the path to the macro on the duet
          ColorChange is the name of the macro
          This is all you need, pretty simple. You can leave the Replace lines in the postprocessing also for single color prints, because they do nothing without a renamend process.
          Thank you so much! I'm going to try and implement this right now! ❤
            vonGreezly
            @vonGreezly:
            @mrac1:
            Quick question! Is it not possible to do this from ONE process (and just have multiple pauses?) or do I need to print using multiple processes to make this work? (whatever works is fine, just curious!)
            -VG
              vonGreezly
              nevermind, answered my own question, that's where it knows when to stop and start printing! got it!
                vonGreezly
                First test print going now… 😄 I shall report my failures and or victories! Thanks guys!
                  vonGreezly
                  M291
                  Error: unsupported command: M291
                    I guess you must be using old firmware. M291 was introduced at version 1.19 AFAIR.
                      vonGreezly
                      1.18.1. Time to update! 😄
                        vonGreezly
                        gonna do it in the morning… want to finish this print I started =\
                        • mrac1undefined
                          mrac1
                          @vonGreezly:
                          Right! I think that's the easiest way.
                          vonGreezlyundefined 1 Reply Last reply Reply Quote 0
                          • mrac1undefined
                            mrac1
                            @dc42:
                            I've used it with 1.20 and 1.21. Btw David, great work!
                              vonGreezly @mrac1
                              @mrac1 OKAY! Back to this.. Finally updated, and Calling the macro generates a popup window, but doesn't pause the print, or move the print head out of the way, etc. So, the Macro is calling, but it's not doing anything other than generating an OK button. Thoughts?
                              My Macro Script (Super simple):
                              M400 ; Wait for moves to complete
                              G1 X10 Y10 F3000 ; Move nozzle to the front
                              M291 P"Change Filament" ; Display message
                              G1 R1 ; go back to the last print move
