    Delta printer Z axis movement vs Z tower movement
    909
    • jmjcoke2undefined
      jmjcoke2
      I need to create an axis that follows the the Z axis of a delta, not the Z tower movement, just the Z coordinate. Other firmwares use the alpha, beta, gamma for the tower movement, is there a way I can separate this in RRF? I have thought of doing this with gcode using a U axis that follows the Z position but I would rather use the hardware.
        Here are two possibilities:
        1. Add a new kinematics class to the firmware, derived from class LinearDeltaKinematics, but with the coordinate transfer functions changed to make the U axis follow the Z coordinate. I may do this myself soon, but I need to complete the RTOS work first.
        2. Use a GCode Post-processor to replace all commands in the GCode file of the form G1 Znn by G1 Znn Unn.
        • jmjcoke2undefined
          jmjcoke2
          Thank you for the info.
          • Danalundefined
            Danal
            @dc42:
            That "GCode Post-processor" could be as simple as a 'sed' command. And there are several 'sed' for windows available.
            I will see if I can come up with an example later tonight.
            • Danalundefined
              Danal
              This works on a Mac, and would be very close on any other platform:
              [[language]]
              sed -E 's/ Z([0-9\.]*)/ Z\1 U\1/g'
              You might NOT need the -E flag on other platforms. Maybe.
              The above will produce the output to stdout, meaning you'd need to > it to another file. Something like
              [[language]]
              sed -E 's/ Z([0-9\.]*)/ Z\1 U\1/g' Original.gcode > Modified.gcode
              • jmjcoke2undefined
                jmjcoke2
                Thanks Danal, I had to fire up the old macbookpro to use sed, it did not work in windows sed but worked great on the mac. I am making a side dump axis that follows the z axis for printing with a Mosaic Pallette+. This will save so much print time and filament.
                • Danalundefined
                  Danal
                  Ooooh… tell me more. I am really itching to get a Pallette+
                    You can get sed for Windows here: http://gnuwin32.sourceforge.net/packages/sed.htm.
