    1.21 I2C Transmission Error
    • timmit99undefined
      timmit99
      I am trying to send a byte value to an Arduino in order for it to activate a feature i am working on. Sending "M260 A2 B49" which should send the byte "1" to the Arduino at address 2. Sending it gives an "Error: M260: I2C transmission error"
      My arduino is started with "Wire.begin(2);" which adds the Arduino to the I2C bus on address 2.
      Not sure what the issue is or how to fix it.
      Here is my Arduino code if this helps:
      #include <Wire.h> //starts the library
      #define LED_1 13
      int x = 0; // give a value to the varable to be change with I/Os
      void setup() {
      Serial.begin(9600); // used to debug
      Wire.begin(2); // Start I2C Bus as a Slave (Device Number 9)
      Wire.onReceive(receiveEvent); // register event
      pinMode(LED_1, OUTPUT);
      for (int i = 0; i < 2; i++)
      digitalWrite(LED_1, HIGH);
      delay(200);
      digitalWrite(LED_1, LOW);
      delay(200);
      void loop ()
      Serial.println(x);
      if (x == 1) {
      delay(200);
      delay(200);
      void receiveEvent()
      x = Wire.read(); // receive byte as an integer
        Is it a 3.3V Arduino, or are you using bidirectional level shifters between the Duet and the Arduino?
        • timmit99undefined
          timmit99
          The board is an Arduino Due which is a 3.3V System.
          I can try an Uno with a 5V level shifter.
            That should be OK then. How long are the I2C wires between the Duet and the Arduino? Can you confirm that you have 3 wires between the two: ground, I2C clock, and I2C data?
