    what can "cause: reset button or watchdog"
    • Potti5undefined
      Potti5
      I have bigbox printer with idex gonfiguration. I dont had any problem before this.
      Everything started yesterday. I had printing on going and suddenly u-axis titan extruder start skipping steps and i have to stop printing.
      Extruder bearing was jammed and i change it to new one. It work again.. i think.
      Today i start to print same print again. everything goes well until i noticed u-axis was skipped steps and print was fail.
      I start to printing again and after first layer Duet board reseting itself and print stopped. I try again and this time reseting happened on layer 6. Now i put voltage meter to measuring if power is going down and i start print again. Power is ok voltage is steady 24.25V but still duet reseting. It happend every print between 1 and 6 layers. I also try to print with X-axis and same thing happen. Any good idea what causing this?
      M122
      [CODE]
      Used output buffers: 3 of 32 (16 max)
      RepRapFirmware for Duet WiFi version 1.20 running on Duet WiFi 1.0 + DueX5
      Board ID: 08DAM-999TL-MQ4S8-6JKFA-3SD6L-9P8RZ
      Static ram used: 15448
      Dynamic ram used: 99240
      Recycled dynamic ram: 4096
      Stack ram used: 1392 current, 6096 maximum
      Never used ram: 6192
      Last reset 00:52:41 ago, cause: reset button or watchdog
      Last software reset time unknown, reason: User, spinning module GCodes, available RAM 7896 bytes (slot 0)
      Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0441f000, BFAR 0xe000ed38, SP 0xffffffff
      Error status: 0
      Free file entries: 9
      SD card longest block write time: 0.2ms
      MCU temperature: min 42.4, current 42.5, max 44.5
      Supply voltage: min 24.3, current 24.5, max 24.8, under voltage events: 0, over voltage events: 0
      Driver 5: standstill, SG min/max not available
      Driver 6: standstill, SG min/max not available
      Driver 7: standstill, SG min/max not available
      Expansion motor(s) stall indication: yes
      Slowest main loop (seconds): 0.063058; fastest: 0.000046
      MaxReps: 0, StepErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
      Bed compensation in use: mesh
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      Network state is running
      WiFi firmware version 1.20
      WiFi MAC address 5c:cf:7f:2b:e7:3e
      WiFi Vcc 3.39, reset reason Turned on by main processor
      WiFi flash size 4194304, free heap 16656
      WiFi IP address 192.168.1.89
      WiFi signal strength -54dBm, reconnections 0, sleep mode modem
      HTTP sessions: 1 of 8
      Socket states: 2 0 0 0 0 0 0 0
      Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
      [/CODE]
      Logs not give anything
      power up + 00:00:00 Event logging started
      power up + 00:00:01 WiFi module started
      power up + 00:00:05 Wifi module is connected to access point ReiDiDin, IP address 192.168.1.89
      power up + 00:00:11 HTTP client 192.168.1.57 login succeeded
      2018-04-18 20:50:38 Date and time set at power up + 00:00:11
      2018-04-18 20:51:43 Started printing file 0:/gcodes/Sodastream_keg v7.gcode
      power up + 00:00:00 WiFi module started
        1. Please upgrade to firmware 1.21.
        2. Please check that the edge of the Duet is not pressing against a back panel or anything else that could be activating the Reset button.
        3. If you are using a USB connection to the Duet, see https://duet3d.dozuki.com/Wiki/USB_ground_loops.
        • Potti5undefined
          Potti5
          1. Check
          2. Check
          3. No usb. Only wifi.
          Result
          Duet reseting print on layer 2 and also wifi going down. Now i cant connect it anymore with wifi.
          M122 i get it with usb
          READ: === Diagnostics ===
          READ: Used output buffers: 1 of 32 (11 max)
          READ: === Platform ===
          READ: RepRapFirmware for Duet 2 WiFi/Ethernet version 1.21 running on Duet WiFi 1.0 or 1.01 + DueX5
          READ: Board ID: 08DAM-999TL-MQ4S8-6JKFA-3SD6L-9P8RZ
          READ: Static ram used: 16152
          READ: Dynamic ram used: 100728
          READ: Recycled dynamic ram: 1904
          READ: Stack ram used: 3576 current, 4600 maximum
          READ: Never used ram: 7688
          READ: Last reset 00:14:24 ago, cause: reset button or watchdog
          READ: Last software reset time unknown, reason: User, spinning module GCodes, available RAM 7896 bytes (slot 0)
          READ: Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0441f000, BFAR 0xe000ed38, SP 0xffffffff
          READ: Error status: 0
          READ: Free file entries: 9
          READ: SD card 0 detected, interface speed: 20.0MBytes/sec
          READ: SD card longest block write time: 0.0ms
          READ: MCU temperature: min 44.5, current 44.7, max 45.2
          READ: Supply voltage: min 24.4, current 24.5, max 24.5, under voltage events: 0, over voltage events: 0
          READ: Driver 0: standstill, SG min/max not available
          READ: Driver 1: standstill, SG min/max not available
          READ: Driver 2: standstill, SG min/max not available
          READ: Driver 3: standstill, SG min/max not available
          READ: Driver 4: standstill, SG min/max not available
          READ: Driver 5: standstill, SG min/max not available
          READ: Driver 6: standstill, SG min/max not available
          READ: Driver 7: standstill, SG min/max not available
          READ: Driver 8: standstill, SG min/max not available
          READ: Driver 9: standstill, SG min/max not available
          READ: Expansion motor(s) stall indication: yes
          READ: Date/time: 1970-01-01 00:00:00
          READ: Slowest main loop (seconds): 0.165896; fastest: 0.000053
          READ: === Move ===
          READ: MaxReps: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
          READ: Scheduled moves: 0, completed moves: 0
          READ: Bed compensation in use: mesh
          READ: Bed probe heights: 0.000 0.000 0.000 0.000 0.000
          READ: === Heat ===
          READ: Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1
          READ: Heater 1 is on, I-accum = 0.0
          READ: === GCodes ===
          READ: Segments left: 0
          READ: Stack records: 1 allocated, 0 in use
          READ: Movement lock held by null
          READ: http is idle in state(s) 0
          READ: telnet is idle in state(s) 0
          READ: file is idle in state(s) 0
          READ: serial is ready with "M122" in state(s) 0
          READ: aux is idle in state(s) 0
          READ: daemon is idle in state(s) 0
          READ: queue is idle in state(s) 0
          READ: autopause is idle in state(s) 0
          READ: Code queue is empty.
          READ: === Network ===
          READ: Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
          READ: HTTP sessions: 0 of 8
          READ: - WiFi -
          READ: Network state is running
          READ: WiFi module is idle
          READ: Failed messages: pending 0, notready 0, noresp 0
          READ: WiFi firmware version 1.21
          READ: WiFi MAC address 5c:cf:7f:2b:e7:3e
          READ: WiFi Vcc 3.38, reset reason Turned on by main processor
          READ: WiFi flash size 4194304, free heap 19648
          READ: Socket states: 0 0 0 0 0 0 0 0
          READ: === Expansion ===
          READ: DueX I2C errors 0
          READ: ok
          SENT: M105
          READ: ok T:39.5 /0.0 31.8 /0.0 B:46.0 /0.0
          log
          power up + 00:00:05 WiFi module is connected to access point ReiDiDin, IP address 192.168.1.89
          power up + 00:00:39 HTTP client 192.168.1.57 login succeeded
          2018-04-19 14:18:12 Date and time set at power up + 00:00:39
          2018-04-19 14:21:10 Started printing file 0:/gcodes/Sodastream_keg v7.gcode
          2018-04-19 14:27:34 Cancelled printing file 0:/gcodes/Sodastream_keg v7.gcode, print time was 0h 6m
          2018-04-19 14:41:38 Started printing file 0:/gcodes/Sodastream_keg v7.gcode
          power up + 00:00:03 WiFi reported error: no known networks found
          power up + 00:00:03 WiFi module is idle
          power up + 00:16:48 Warning: VIN under-voltage event (8.6V)
          power up + 00:00:36 HTTP client 192.168.1.57 login succeeded
          2018-04-19 15:07:34 Date and time set at power up + 00:00:36
          taking power off get wifi up again
          • Potti5undefined
            Potti5
            Is a possible that u-axis stepper motor can couse this? I take that plug off and now print is going on layer 10.
            It skipping steps when this started and it never skip before. I drive it manually yesterday and it work well. Intresting....
              If disconnecting the U axis motor solved it, here are some possibilities:
              • Insufficient power to drive all the motors
              • Bad U axis driver - is it getting hot?
              • Short in U axis motor wiring
              • Potti5undefined
                Potti5
                It look like it would work now.
                I have had this idex setup about 6month now and i am printed quite lot whitout problem. This print is printed only one material so only one (u or x) motor is used. Both axis have same kind and tall wiring. I check board with thermocraphy cameras after this print so we see how much those driver warm up.
                Maybe i could also try to place u-axis motor to another driver before i start to change that motor.
