Dual Z independent setp
I am trying to setup the the Dual Z motors so they are independent. I plugged the 2nd motor in to my E1 space. What else am I missing to do? As only one motor is running.
M667 S1 ; Select CoreXY mode ; Network M550 PCrimReaper ; Set machine name M552 S1 ; Enable network M587 S"SD6 2.4" P"drakkar#99" ; Configure access point. You can delete this line once connected M586 P0 S1 ; Enable HTTP M586 P1 S0 ; Disable FTP M586 P2 S0 ; Disable Telnet ; Drives M569 P0 S1; Drive 0 goes forwards (X) M569 P1 S1; Drive 1 goes forwards (Y) M569 P2 S0; Drive 2 goes backwards (Z1) M569 P3 S0; Drive 3 goes backwards (E0) M569 P4 S0; Drive 4 goes backwards (Z2 in the E1) ;Dual Z M584 X0 Y1 Z2:4; Two Z motors connected to driver outputs 2 and 4 M671 X15:305 Y162:162 S0.5; leadscrews at mid left, and mid right M350 X32 Y32 Z32:32 E32 I1 ; Configure microstepping with interpolation M92 X160 Y160 Z2000 E160 ; Set steps per mm M566 X500 Y500 Z10 E420 ; Set maximum instantaneous speed changes (mm/min) M203 X3000 Y3000 Z180 E1200 ; Set maximum speeds (mm/min) M201 X500 Y500 Z4 E500 ; Set accelerations (mm/s^2) M906 X1000 Y1000 Z1000 E1000 I30 ; Set motor currents (mA) and motor idle factor in per cent M84 S5 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; Set axis minima M208 X320 Y320 Z380 S0 ; Set axis maxima ; Endstops M574 X1 Y2 S0; Set active low endstops ; Z-Probe M574 Z1 S2 M558 X0 Y0 Z1 P1 H5 F1000 T6000 ; Set Z probe type to unmodulated and the dive height + speeds G31 P490 X42 Y-20 Z0.138 ; Set Z probe trigger value, offset and trigger height M557 X15:305 Y15:305 S40 ; Define mesh grid ; Heaters M305 P0 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 0 M143 H0 S120 ; Set temperature limit for heater 0 to 120C M305 P1 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 1 M143 H1 S280 ; Set temperature limit for heater 1 to 280C ; Fans M106 P0 S0.3 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on M106 P2 S1 I0 F500 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on ; Tools M563 P1 D0 H1 ; Define tool 1 G10 P1 X0 Y0 Z0 ; Set tool 1 axis offsets G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C ; Automatic saving after power loss is not enabled ; Custom settings are not configured ; Miscellaneous T1 ; Select first tool
; bed.g ; called to perform automatic bed compensation via G32 ; ; generated by RepRapFirmware Configuration Tool on Tue Mar 20 2018 20:29:09 GMT-0400 (Eastern Daylight Time) M561 ; clear any bed transform G30 G30 P0 X0 Y160 Z-99999; probe near a leadscrew G30 P1 X320 Y160 Z-99999 s2; probe near a leadscrew and calibrate 2 motors G30
Helps if you have the jumpers in place haha
