    Probable hardware fault
    • Julianundefined
      Julian
      Duet3D Eth + Duex5
      Motor connected to P0 moves when P 7,8,9 are stepping.
      Only this driver is affected - there is a good earth between the boards.
      CoreXY - P7,8,9 are used for 3 lead screws Z axis - P1 is 'Y' - currently P6 is 'X' .
      I can confirm that this unwanted movement happens even if P0 is not "in use" - I connected an extruder motor to P0, whilst 'X' was on P6 - it moved when the Z axis moves.
      This is a new board, nothing has been plugged/unplugged with power on. I have made no further attempts to diagnose (no scoping!).
      Any suggestions would be welcomed - thanks
      • Qdeathstarundefined
        Qdeathstar
        Hi.
        I’m not an expert on this but it may be possible this is a software fault. It is possible to remap p0 to different axis via M584.
        What happens if you try to move the extruder?
        I would post a picture of your printer, board connections, and config.g find so when someone with more experience in this sees the thread they can better help
          dc42 administrators @Julian
          @julian said in Probable hardware fault:
          Duet3D Eth + Duex5
          That is a most unlikely hardware fault, more likely a configuration issue. Please post your config.g file.
            deckingman
            If you've re-mapped the drives using M584 it doesn't remove their old assignment so it's important to explicitly assign ALL drives. However, I'm not sure if this would cause the problem because P0 would normally be X so if you've mapped X to P6 and left P0 unassigned, then I'd have thought that it would move when you move X rather than Z but you never know.....
            As David said, post your config.g
            • Julianundefined
              Julian
              I tried allocating the 'unused' motors - made no difference.
              Having looked at the schematic I understand why hardware fault seems "most unlikely"!
              I can confirm that a motor connected to P0 rotates in sympathy with Z axis - P7,8,9 - whether it is allocated to an 'E' or not, config.g: (Max speed on X,Y is probably too high - was experimenting)
              ; Configuration file for Duet Ethernet (firmware version 1.20 or newer)
              ; generated by RepRapFirmware Configuration Tool on Sun Apr 15 2018 16:25:27 GMT+0100 (GMT Daylight Time)
              ; Much modified since
              M550 PJWB_DBot_1 ; Set machine name
              M551 Ppasswordhere ; Set password
              M540 PBE:63:4C:40:53:55 ; Set MAC address
              ;Working off network main presently
              ;M552 P0.0.0.0 S1 ; Enable network and acquire dynamic address via DHCP
              M552 P10.0.0.28 S1
              M586 P0 S1 ; Enable HTTP
              M586 P1 S0 ; Disable FTP
              M586 P2 S0 ; Disable Telnet
              M569 P0 S0 ; Drive 0 goes forwards
              M569 P1 S0 ; Drive 1 goes forwards
              M569 P5 S0
              M569 P6 S0
              M569 P7 S0
              M569 P8 S0
              M569 P9 S0
              M667 S1 ; CoreXY
              M584 X6 Y1 Z:7:8:9 E3:4:0:5:2 ; Apply custom drive mapping
              M350 X16 Y16 Z16 E16:16 I1 ; Configure microstepping with interpolation
              M92 X100 Y100 Z400 E600:600 ; Set steps per mm
              M566 X900 Y900 Z12 E36:36 ; Set maximum instantaneous speed changes (mm/min)
              M203 X50000 Y50000 Z180 E1500:1500 ; Set maximum speeds (mm/min)
              M201 X1000 Y1000 Z250 E120:120 ; Set accelerations (mm/s^2)
              M906 X1200 Y1200 Z800:800:800 E800:800 I30 ; Set motor currents (mA) and motor idle factor in per cent
              M671 X150:354:-54 Y-71.5:282.5:282.5 S3 ; leadscrews at rear middle, front left and front right; max correction (1 is default)
              M84 S30 ; Set idle timeout
              M208 X0 Y25 Z0 S1 ; Set axis minima
              M208 X300 Y300 Z300 S0 ; Set axis maxima
              M574 X1 Y2 S0 ; Set endstops (y = max), XY active low
              M574 Z1 S2 ; Set endstops controlled by probe
              M558 P9 H3 F200 T5000 ; Homing Z axis, P9 for BLTouch
              G31 P5 X-36 Y20 Z1 ; Set Z probe offset and trigger height,Set the G31 P parameter to a low value, because the BLTouch produces only a short output pulse
              M557 X36:264 Y45:280 S20 ; Define mesh grid
              M307 H7 A-1 C-1 D-1 ; Disable Duex heater 5 (used for BLTouch, see deploy & retract probe.g)
              ; Heaters - not yet set up
              M301 H0 S1.00 P10 I0.1 D200 T0.4 W180 B30 ; Use PID on bed heater (may require further tuning)
              M305 P0 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 0
              M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
              M305 P2 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 2
              M143 H2 S280 ; Set temperature limit for heater 2 to 280C
              ; Fans - not yet configured
              M106 P0 S0.3 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
              M106 P1 S1 I0 F500 H1:2 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
              M106 P2 S1 I0 F500 H1:2 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
              ; Tools - not yet configured
              M563 P0 D0 H1 ; Define tool 0
              M563 P1 D1 H2 ; Define tool 1
              G10 P1 X0 Y0 Z0 ; Set tool 1 axis offsets
              G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C
              M501 ; Load saved parameters from non-volatile memory
                Remove the : between Z and 7.
                Julianundefined 1 Reply Last reply Reply Quote 0
                • Julianundefined
                  Julian @dc42
                  @dc42 Thank you that fixed it.
                  I see how that would work, not sure whether to feel embarrassed at not having spotted it - or peeved that it accepted a 'default' that I never intended ☺ .
                  Sorry to have troubled you!
