    What determines the Z-zero point
    • Captain_squndefined
      Captain_sq
      Hi guys,
      I have a Tronxy X5S which I have fitted a Duet Wifi and a custom made extruder. The Duet is using independent drives for the two Z-motors and I have setup a macro for the leadscrews compensation using the Escher IR-probe that works nicely. The old Z-home sensor is used as before connected to the Z-endstop sensor input.
      Now, the question is, what of these determines the actual Z-zero position? Is it the Z-endstop homing sensor or is it the leadscrew compensation bed probe operation?
      Custom made Kossel Mini - Duet WiFi / Modded Tronxy X5S - Duet WiFi / Prusa i3 MKIII
      Embedded systems designer, RC Pilot, maker and Gadget-o-holic
        dc42 administrators @Captain_sq
        @captain_sq said in What determines the Z-zero point:
        Hi guys,
        Both homing and leadscrew adjustment set the Z=0 position, so whichever happens latest will be the one that matters. For example, if you have a G28 homig command in your slicer start GCode, that homing operation will reset the Z=0 position.
