Wifi Connectivity issue
I am having issues with my duet board connecting to wifi router. Over past several day I have tried several things but the issue keeps recurring to the points that I am frustrated with the board.
Tried to recycle power, use on-board reset button, set specific channels on the router, moving the router just next to the board, Telnet to the board and update the wifi firmware
Few of things that I noticed:
- after flashing the wifi the board most likely connects.
- In between the power cycles the wifi connects when the on-board wifi LED blinks and then turns solid. Mostly, the blue wifi led glows directly without blinking and in such cases the board is never connected to the router.
Pls advice.
Which main and wifi firmware versions are you using? Version 1.21 is recommended. The upgrade process from firmware 1.19 or later is straightforward, but from 1.18 or earlier it is more complicated.
See https://duet3d.dozuki.com/Wiki/WiFi_disconnections_and_AJAX_timeout_errors.
I had upgraded to Firmware 1.21, however not sure if the wifi issues started prior to the upgrade or after....
=========::details from web interface:===========
Firmware Version: 1.21 (2018-03-21)
WiFi Server Version: 1.21
Web Interface Version: 1.21==========================
Few other points: once the wifi is connected I do not have any issues with disconnections / timeouts. the web interface responds for whole duration of print, even after 12+ hours
Is there any reason for the wifi led on the board to glow solid blue directly before blinking a few times, after powering on
I don't know why the blue LED would glow solid blue after turn on. Next time it happens, please send M122 via USB to get a diagnostic report. The "Wifi reset reason" may give us a clue.
Are you using the internal 5V regulator to provide the 5V power, or are you providing 5V power by other means?
Today I had another round of issue with the wifi connectivity. As suggested, here are the M122 dumps
M122<CR>
Used output buffers: 1 of 32 (1 max)
RepRapFirmware for Duet 2 WiFi/Ethernet version 1.21 running on Duet WiFi 1.02 or later
Board ID: 08DDM-9FAM2-LW4S4-6JTDA-3S86K-KMSVX
Static ram used: 16152
Dynamic ram used: 100448
Recycled dynamic ram: 2184
Stack ram used: 3576 current, 4528 maximum
Never used ram: 7760
Last reset 00:01:13 ago, cause: power up
Last software reset time unknown, reason: User, spinning module GCodes, available RAM 7760 bytes (slot 0)
Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0441f000, BFAR 0xe000ed38, SP 0xffffffff
Error status: 0
Free file entries: 10
SD card longest block write time: 0.0ms
MCU temperature: min 47.3, current 49.3, max 49.4
Supply voltage: min 23.9, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0
Slowest main loop (seconds): 0.000214; fastest: 0.000049
MaxReps: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
Bed compensation in use: none
Segments left: 0
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is idle in state(s) 0
serial is ready with "M122" in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
Code queue is empty.
=== Network ===
HTTP sessions: 0 of 8- WiFi -
Network state is starting
WiFi module is disabled
=== Expansion ===
ok
M122<CR>
Last reset 00:00:30 ago, cause: power up
Error status: 0
MCU temperature: min 46.5, current 49.3, max 49.4
Supply voltage: min 23.8, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0
Slowest main loop (seconds): 0.000212; fastest: 0.000049
Segments left: 0
=== Network ===
=== Expansion ===
ok
RepRapFirmware for Duet 2 WiFi/Ethernet Version 1.21 dated 2018-03-21
Executing config.g...Kinematics is CoreXY with axis factors X:1.000 Y:1.000 Z:1.000
Error: M587: Failed to add SSID to remembered list
HTTP is enabled on port 80
FTP is disabled
TELNET is enabled on port 23Done!
M552 S0
okM122
Stack ram used: 3576 current, 4476 maximum
Never used ram: 7812
Last reset 00:01:09 ago, cause: power up
Error status: 0
MCU temperature: min 46.6, current 50.5, max 50.8
Supply voltage: min 0.4, current 0.5, max 0.7, under voltage events: 0, over voltage events: 0
Driver 0: ok, SG min/max not available
Driver 1: ok, SG min/max not available
Driver 2: ok, SG min/max not available
Driver 3: ok, SG min/max not available
Driver 4: ok, SG min/max not available
Slowest main loop (seconds): 0.000188; fastest: 0.000044
Segments left: 0
=== Network ===
=== Expansion ===
ok
M552 S1
Turn off the current WiFi mode before selecting a new one
ok
M552 S0
ok
M122
Used output buffers: 1 of 32 (9 max)
Stack ram used: 3576 current, 4548 maximum
Never used ram: 7740
Last reset 00:02:41 ago, cause: power up
Error status: 0
MCU temperature: min 50.5, current 51.3, max 51.5
Supply voltage: min 0.4, current 0.5, max 0.5, under voltage events: 0, over voltage events: 0
Slowest main loop (seconds): 0.003174; fastest: 0.000044
Segments left: 0
=== Network ===
=== Expansion ===
ok
FTP is disabled
RepRapFirmware for Duet 2 WiFi/Ethe - WiFi -
The wifi module has failed to respond to the startup command. One reason may be that you have a M587 command in config.g. Please remove that command.
Yes you are right, I have M587 in config.g
M550 PMy_Printer ; Set machine name
M552 S1 ; Enable network
M587 S"########" P"######" ; Configure access point. You can delete this line once connected
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M586 P2 S1 ; Enable Telnet -
Removed M587 command but still continue to face issues...pls advice
If M122 always reports that the network state is Starting when you are having this problem and you run M122, and you are definitely running version 1.21 of both main and WiFi firmware, then I think the WiFi module is faulty. In which case, ask the supplier of your Duet to replace it.
Finally, had the wifi module replaced on Duet board and everything is a charm again. Thanks for the pointing out.
