DC42 IR Probe - Only one time flashing and showing 1000
IR Height Sensor
    Sen
    Hi all,
    I have bought my second Duet3D Wifi board because of my new printer (CoreXY) and this time I used DC42 IR Probe. I have successful upgraded to firmeware 1.21, so my homex and homey work very well.
    For the last two days I am trying to get the IR Probe correctly running but I am stucking there. When I start my duet board it looks like the red LED only flashing one time and of course I put the M558 to P1 but the zprobe value what I have got is only 1000 and it is slowly decreasing to 958 and stucking there. It change between 957 and 958. Also nothing happen when I put a paper below the IR Probe.
    I did it step by step according to dc42 guide: https://miscsolutions.wordpress.com/mini-height-sensor-board/
    The IR Probe is also showing no led light and when I try to homez I just get the message:
    Error: Z probe already triggered at start of probing move
    Error: G0/G1: insufficient axes homed
    Following the IR part of my config.g:
    M558 P1
    G31 X0 Y30 Z2.003 P500
    If I use Mode P2 then it is about 470-530 and the light at the probe is all the time red. But it dont seems that anything what I do, eg. put a paper below the sensor below, dont change anything.
    and the homez:
    G91
    G1 Z5 F800 S2
    M401
    G90
    G1 X120 Y125 F2400
    G30
    M402
    G1 Z2 F200
    So actually I am at the end of that what I know to check and maybe one of you guys could give me some help and support what I should do to solve this issue.
    Thanks
      Check the ground connection between the IR sensor and the Duet. Also check visually that the ground (centre) pin of the IR sensor looks properly soldered to the PCB.
      2 out of 2
