Z endstop not homing
I am having an issue withe the Z motor continuing to lower the extruder even after the homing switch is triggered. The X and Y axes home properly and stop as they should.
I have them all set as active low and in the web interface It even shows the endstop is active when triggered. It just continues to move down anyway. I'm sure I have the correct one connected as I activated all three just to be sure. Has anyone else had this issue? -
Have you seen #1 in the FAQ at https://duet3d.dozuki.com/Wiki/FAQ ?
Got it all sorted, thank you for the link.
