    Homed Height
    2.0k
      dc42 administrators @bulka
      @bulka said in Homed Height:
      ok ..my step motors are 0.9 ...I think I should double the value and use 160
      Yes, if you are using 20-tooth pulleys. If your pulleys are 16-tooth then it should be 200.
      • bulkaundefined
        bulka
        yes is a pulley 20T. thx 🙂
        I corrected the config file and now the H is what I measured:
        M555 P1 ; Set firmware compatibility to look like RepRapFirmare
        M665 R55.41 L355.00 H366.75 B170.00
        M666 X0 Y0 Z0
        M569 P0 S0 ; Drive 0 goes forwards
        M569 P1 S0 ; Drive 1 goes forwards
        M92 X160 Y160 Z160 E663 ; Set steps per mm
        M566 X2400 Y2400 Z2400 E1200 ; Set maximum instantaneous speed changes (mm/min)
        M203 X36000 Y36000 Z36000 E1200 ; Set maximum speeds (mm/min)
        M201 X1000 Y1000 Z1000 E1000 ; Set accelerations (mm/s^2)
        M906 X1200 Y1200 Z1200 E700 I60 ; Set motor currents (mA) and motor idle factor in per cent
        M84 S15 ; Set idle timeout
        M208 Z0 S1 ; Set minimum Z
        M574 X2 Y2 Z2 S1 ; Set active high endstops
        M558 P5 R0.4 H5 F120 T6000 ; Set Z probe type to effector and the dive height + speeds
        G31 P100 X0 Y0 Z-0.252 ; Set Z probe trigger value, offset and trigger height
        M557 R85 S20 ; Define mesh grid
        M143 H0 S100 ; Set temperature limit for heater 0 to 100C
        M305 P1 X200 ; Configure thermocouple for heater 1
        M143 H1 S330 ; Set temperature limit for heater 1 to 330C
        M106 P0 S0.3 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
        M106 P1 S1 I0 F500 H1 T40 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
        M106 P2 S1 I0 F500 H1 T40 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
        M563 P0 D H1 ; Define tool 0
        • bulkaundefined
          bulka
          I changed the calibration on bed config file using :http://www.escher3d.com/pages/wizards/wizardbed.php
          • bulkaundefined
            bulka
            what I'm not sure about this command ... the parameter R and L ( don't kill me )
            I don't understood perfectly how to calculate it... 😞
            I changed the M558 as suggested in the wiki ( and by you ) to M558 P5 R0.4 H20 F120 T6000
              L is the rod length measured between bearing centres. If you are using Haydn Huntley's magnetic rods, each rod carries a label on which its length is written, so use that figure.
              R is the delta radius. The exact value will be found by calibration, so you need to provide only an approximate value. Use the horizontal distance subtended by any rod, measured between bearing centres, when the effector is central.
              • bulkaundefined
                bulka
                ok.
                changed to:
                M665 R168 L360 H366.75 B170.00
                M666 X0 Y0 Z0
                I'll try to start auto calibration 🙂
                • bulkaundefined
                  bulka
                  Calibrated 6 factors using 16 points, deviation before 1.322 after 0.029
                  • bulkaundefined
                    bulka
                    change calibration to 7 factor:
                    Calibrated 7 factors using 16 points, deviation before 1.201 after 0.016
                    • Dougal1957undefined
                      Dougal1957 @bulka
                      @bulka not wise to use 7 factor if you know your rod length properly use either 6 or 8
                      • bulkaundefined
                        bulka
                        ok, I read after your answer on wiki: " typical delta printer builds, 6-factor is best"
                        Changed beg config file:
                        13:21:29
                        Calibrated 6 factors using 16 points, deviation before 0.017 after 0.014
                        13:23:13
                        M665
                        Diagonal 363.663, delta radius 173.193, homed height 366.386, bed radius 170.0, X -0.034°, Y -0.209°, Z 0.000°
                        13:23:09
                        M666
                        Endstop adjustments X0.20 Y0.83 Z-1.03, tilt X0.00% Y0.00%
                        If I'm not wrong...after calibration....the Diagonal was changed....it's wrong to use 6 factors using 16 points?
                          Dougal1957 @bulka
                          @bulka the drag rod length was changed by the previous 7 factor cal you need to manually reset the rod length and run it again with either 6 or 8 factor cal
                          • bulkaundefined
                            bulka
                            done 🙂 thank you
                            thank you DC 🙂
