Impossible to flash my Duet wifi
I received my duet a week ago, I installed it and configured it, I was able to print but two days ago I lost the wifi and tried to reconfigure it with the Yat but it did not respond or recognize the Duet as an external device, I tried to install the driver again but it has been impossible for what I searched in the forum and I have seen a post in which they commented that the card should be flashed again, I have tried in several ways, with external power, without it, removing all the cables connected to the plate, with two different computers, several cables and it has been impossible, I tried Bossa and the same, I can not flash the board, any suggestions? in the attached video you can see the process.
Thank youhttps://www.youtube.com/watch?v=E76Fq1krF34&feature=youtu.be
What is the file size of the DuetWiFiFirmware.bin that you are trying to flash? It should be over 300Kb. I think your file may be much shorter than that. The download area is https://github.com/dc42/RepRapFirmware/releases.
The sd card must be inserted when i'm flashing with Sam-ba or it doesn't matter?
@m0de said in Impossible to flash my Duet wifi:
It doesn't matter.
@dc42 Hi, I tried with the file you sent me and nothing again, i don't know if i'm missing something or what but i'm not able to flash the duet.
https://www.youtube.com/edit?o=U&video_id=PNkdRx7adss -
Your video link doesn't work for me.
Did you check the size of the DuetWiFiFirmware.bin file?
Hi, yes the size is 372, try with this link please: https://youtu.be/PNkdRx7adss
At 1:41 in the video SAM-BA reported "Sent file and memory do not match". So programming failed.
Please try using Bossa instead. Instructions are at the end of https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Fallback_procedure_Num_3.
Nothing, i don't know if i'm doing something wrong.
https://youtu.be/A-Cq0FEep74
This is my Duet i'm using the Duetwififirmware, this is right? -
Yes, DuetWiFiFirmware.bin or Duet2CombinedFirmware.bin from the 1.21 release area is correct for that Duet.
What happens if you write the firmware using Bossa, but after that click Verify?
do the windows drivers need to be loaded before the port will be recognised after flashing?
could that be why it isn't being recognised afterwards?
I would expect Device Manager to report "Unknown device" if the Duet was detected but no driver for it was found. You do have a couple of unknown devices showing, but they are flagged "Dispositivo base del sistema" which according to Google Translate means "Base device of the system".
@dougal1957 said in Impossible to flash my Duet wifi:
If i try to install de driver in the ports you can see nothing happen, i don't know what's that but is not the due because if i plug or unplug the Duet that ports still there and if i install the Duet driver an error message appear. -
Thank you, Bossa is getting verify errors, just like SAM-BA did. Please ask your suppler to replace the Duet under warranty.
I bought it on your web, how can I send the Duet?
