    confirm of jumpers and fans
    • wepollockundefined
      wepollock
      Just a hand holding request to confirm so I don't mess up
      I have the board positioned vertically in a project box; with the steppers towards top (north).
      (there is a fan pointed to the back of the card
      Power in positive is the connection closest to the steppers.
      Fan negative is left towards the SD card
      Being a delta Z will be the furthest most top right (north east) connection.
      With one stepper the jumpers in Z2 remain in place.
      I am going to use internal 12v from the power supply for fans -
      ---vfan jumper select should be rightmost two pins.
      And I am going to use internal 5v for the board
      ---the middle jumper pair should be closed, the rightmost jumper pair empty.
        Yes that's all correct.
