    Duet WiFi - User Interface
    My Duet controlled machine
    1.8k
    • jmshepundefined
      jmshep
      I normally us Chrome and have reset the settings to defaults and also tried using Edge and still get the same results as before.
      • Danalundefined
        Danal
        The free chrome plug-in "Local Storage Manager" may help give you insight as to what is going on.
        • jmshepundefined
          jmshep
          I have downloaded the suggested extension and can see that the settings data is recorded but not retained when the Duet interface is closed down. I have also deleted the Chrome default profile and allowed it to build a new one but the problem still persists. (the option to clear data on close down in Chrome settings is not enabled).
          Any other suggestions welcome.
            Perhaps you have disabled cookies?
              Can you try creating a new user profile on your computer and testing from that account?
              • Danalundefined
                Danal
                Try:
                chrome://settings/content/cookies
                In the omnibox. Even though it says "cookies" there are settings on that page that affect local data as well. They are fairly self explanatory.
                • MSquaredundefined
                  MSquared
                  @dc42 Just curious is there a reason that the settings are not persisted to the SD card?
                  resamundefined 1 Reply Last reply Reply Quote 0
                  • resamundefined
                    resam @MSquared
                    @msquared The next DWC release will do exactly that:
                    DWC settings are uploaded to and downloaded from the Duet board by default
                    https://github.com/chrishamm/DuetWebControl/commit/a0b0a18733ae75b63e7c286e454b8d2713bec35e
                    0 chrishamm committed to chrishamm/DuetWebControl
                    Version 1.21.1-b1
                    Added new 'O' status character to indicate that the machine has been turned off
                    Added support for 9 total fans whose visibility is set via the new
                    'controllableFans' bitmap field of the advanced status response
                    Implemented more granular control of pop-up notifications and made them wider on small devices
                    If a JavaScript error occurs, the message is no longer closed when the connection is re-established
                    Spindle RPM of multiple tools can be set (requires RRF 1.21.1 or later)
                    JSON files are automatically opened via the text editor when double-clicked
                    Clicking on heater links activates them, then puts them into standby mode and eventually turns them off
                    More OEM enhancements
                      There are advantages and disadvantages to both approaches. You might want to use different settings on a smartphone or tablet compared to a PC, and with the settings stored on the SD card, you won't be able to do that.
                      • jmshepundefined
                        jmshep
                        OK I Have tried most of the suggestions and checked settings again. I toggled all relevant settings in Chrome on and off and deleted all the cookies and tried again. Now I can see the Duet cookie in Chrome settings and if I make changes to DWC, apply settings and then close Chrome and re open DWC, the settings are retained BUT just one time!
                          Are you sure you don't have "Keep local data only until you quit your browser" enabled in Chrome?
