Problem with uploaded stl file
Firmware developers
1.0k
    mickey30m
    Hi there,
    when i upload a stl file (drag and drop on the upload button)
    the duet goes crazy, i get then a http error and the duet can not connect anymore.
    i must power off a couple of minutes to activate the duet again.
    are there more people have this?
      resam
      Why are you uploading an STL file?
      The Duet requires g-code files to print. You need to use a software to slice your STL models into g-code.
        mickey30m
        i know
        but is er no protection or warning?
          ShadowX
          Yeah, the protection is when it goes crazy. Try sending an .EXE file or .HTML as your next test.
            mickey30m
            It was not a test. I select the wrong file.
            But then i het problems with the board.
            I though maybe is it a good Idea to protect that OR something.
            I dont think i AM the first one that select a stl file 😉
              Probably would be a good idea to have some error rejection built in to the upload function. Maybe this can get moved to the DWC/firmware wishlist section?
              6 out of 6
