    M203 Max Speed
    • Quadcellsundefined
      Quadcells
      M203 Max speed, does this override the Default Printing Speed in the Simplify3D slicer?
      /quadcells
        Quadcells
        Let me change how I asked the question:
        What settings do I need to change so I can speed up my Delta printer. Are these settings in both Slicer and Duet firmware?
        One of the reasons i built a Delta was for speed and size of prints.
        I have a Qidi Tech X-One (Cartesian) which prints at the same speed as the Delta I built.
        /quadcells
          The M203 setting is the never-exceed-speed. So it should be higher than your printing speed and travel speed settings in slic3r. A typical value for a delta would be 12000mm/min i.e. 200mm/sec. Don't set it so high that your printer starts to skip steps when you command movement at maximum speed.
