    Getting conected after changes
    1.3k
    • Mikesplaneundefined
      Mikesplane
      Hi I have had my duet 3d wifi for some years now but have changed my printer and laptop I just can' t seem to remember how to get going again. i can see a control panel I have always used but it bis a simulation and wont let me do anything please help.
      Regards
      Mike
        Which firmware version is your Duet WiFi running?
          Mikesplane
          Hi, firmware 1.7 Reprapfirmware.
          mike
            That's quite old, and there were major changes at version 1.19. I suggest you upgrade to version 1.21. See https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Upgrading_to_DuetWiFiFirmware_1_Num_19 for the special procedure for upgrading from pre-1.19 to 1.19 or later. You can use that procedure to migrate directly to 1.21, but read the upgrade notes for 1.21 and the versions you skipped.
              Mikesplane
              Is there any way I can buy a card with this done? I am the worlds worst at doing this sort of thing I am more of a build man than a techno man. Thanks Mike
                It's not just a matter of changing the SD card because two sets of firmware on the Duet need to be changed too.
                  Mikesplane
                  This is were I have got to,
                  Still don't understand what this means
                  READ: G90
                  Testing binary communication protocol...
                  Connected to machine!
                  SENT: d501015e
                  READ: d501015e
                  This printer only supports binary commands.
                  Disconnected.
                  Attempting connection at \.\COM3...
                  Testing plaintext communication protocol...
                  READ: G90
                  SENT: d501015e
                  READ: d501015e
                  this is what I get when I try to use M997 S1
                  Mike
                    dc42 administrators @Mikesplane
                    @mikesplane said in Getting conected after changes:
                    READ: G90
                    SENT: d501015e
                    READ: d501015e
                    Disconnected.
                    READ: G90
                    SENT: d501015e
                    READ: d501015e
                    Mike
                    What program are you using to communicate with the Duet? I don't recognise those responses.
