    duet wifi connection issues
    Firmware installation
    2.4k
    • IanWaltonundefined
      IanWalton
      === Diagnostics ===<LF>Used output buffers: 1 of 32 (1 max)<LF>=== Platform ===<LF>RepRapFirmware for Duet 2 WiFi/Ethernet version 1.21 running on Duet WiFi 1.02 or later<LF>Board ID: 08DDM-9FAM2-LW4S4-6J1D8-3SD6R-T3SZX<LF>Static ram used: 16152<LF>Dynamic ram used: 100248<LF>Recycled dynamic ram: 2384<LF>Stack ram used: 3576 current, 4528 maximum<LF>Never used ram: 7760<LF>Last reset 01:25:57 ago, cause: power up<LF>Last software reset time unknown, reason: User, spinning module GCodes, available RAM 7688 bytes (slot 2)<LF>Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0441f000, BFAR 0xe000ed38, SP 0xffffffff<LF>Error status: 0<LF>Free file entries: 10<LF>SD card 0 detected, interface speed: 20.0MBytes/sec<LF>SD card longest block write time: 0.0ms<LF>MCU temperature: min 28.8, current 30.8, max 31.4<LF>Supply voltage: min 12.2, current 12.2, max 12.3, under voltage events: 0, over voltage events: 0<LF>Driver 0: standstill, SG min/max not available<LF>Driver 1: standstill, SG min/max not available<LF>Driver 2: standstill, SG <Warning: Maximal number of bytes per line exceeded! Check the end-of-line settings or increase the limit in the advanced terminal settings.>
      M587 with no pparameters returns
      Error: M587: Failed to retrieve network list<LF>
      ayudteeundefined 1 Reply Last reply Reply Quote 0
      • ayudteeundefined
        ayudtee @IanWalton
        @ianwalton If your Setnetwork macro still exists in its default location, execute it in the console by sending "M98 P/macros/SetNetwork". Then send a M587 and check that your network is listed, and then send a M552 S1. Every once in a while my duet wifi does this and this is the procedure that works for me. I'm tempted to get a paneldue to make things easier than fetching the usb cable, but the usb cable has always worked so far when the network stalls. Good luck.
        IanWaltonundefined 2 Replies Last reply Reply Quote 0
          Please change the line end sequence in YAT (if that is what you are using) to LF and run M122 again.
          I suspect that you have an incompatible version of DuetWiFiServer.bin installed, and/or that you are not enabling wifi in config.g.
            IanWalton @ayudtee
            @ayudtee it does exist there, i updated it in an external sd reader, reinstalled it in the duet board and tried running it.
            came back
            Warning: Macro file /macros/SetNetwork not found.
              IanWalton @dc42
              SENDING:M122
              Dynamic ram used: 100448
              Recycled dynamic ram: 2184
              Last reset 00:00:21 ago, cause: software
              Last software reset time unknown, reason: User, spinning module GCodes, available RAM 7864 bytes (slot 3)
              Error status: 0
              MCU temperature: min 31.6, current 31.9, max 32.0
              Supply voltage: min 12.2, current 12.3, max 12.3, under voltage events: 0, over voltage events: 0
              Slowest main loop (seconds): 0.000259; fastest: 0.000049
              MaxReps: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
              Bed compensation in use: none
              Segments left: 0
              Movement lock held by null
              http is idle in state(s) 0
              telnet is idle in state(s) 0
              file is idle in state(s) 0
              serial is ready with "M122" in state(s) 0
              aux is idle in state(s) 0
              daemon is idle in state(s) 0
              queue is idle in state(s) 0
              Code queue is empty.
              === Network ===
              HTTP sessions: 0 of 8
              • WiFi -
                Network state is starting
                WiFi module is disabled
                === Expansion ===
              network state is starting
              wifi module is disabled
              hmmm, ive got a spare sd card somewhere, going to try reformatting it and starting fresh
                IanWalton @ayudtee
                @ayudtee
                sigh, im a dumbass, macro wasnt correct name, but, i corrected it and got it to run
                hasnt changed anything though 😞
                  IanWalton @dc42
                  config file contents
                  ; Configuration file for Duet WiFi ver 1.
                  M555 P1 ; Set firmware to look like RepRapFirmare
                  M550 PCR10 ; Set machine name
                  M552 S1 ; Enable network
                  M587 S"PLUSNET-Q6QW" P"xxxxxxxx" ; access point
                  M350 X16 Y16 Z16 E16 I1 ; Configure microstepping
                  M92 X80 Y80 Z4000 E420 ; Set steps per mm
                  M566 X900 Y900 Z12 E120 ; Set maximum speed changes
                  M203 X6000 Y6000 Z180 E1200 ; Set maximum speeds
                  M201 X500 Y20 Z250 E250 ; Set accelerations
                  M906 X800 Y800 Z800 E800 I30 ; Set motor currents (mA)
                  M84 S30 ; Set idle timeout
                  M208 X300 Y300 Z400 S0 ; Set axis maxima
                  M574 Y2 S1 ; Set active high endstops
                  M574 X1 Z1 S2 ; Set endstops controlled by probe
                  M558 P1 H5 F120 T6000 ; Set Z probe type to unmodulated and the dive height + speeds
                  G31 P500 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
                  M557 X45:275 Y45:275 S20 ; Define mesh grid
                  M305 P1 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 1
                  M106 P0 S0.3 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                  M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                  M106 P2 S1 I0 F500 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
                  M563 P0 D0 H1 ; Define tool 0
                  ; Automatic power saving
                  M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
                  ;M501 ; Load saved parameters from non-volatile memory
                    @ianwalton said in duet wifi connection issues:
                    WiFi -
                    That bit suggests either an incomplete wifi firmware installation or an incompatible wifi firmware version. I suggest you do this:
                    • download DuetWiFiServer.bin again from https://github.com/dc42/RepRapFirmware/releases/tag/1.21
                    • use a PC to copy it into /sys on the SD card
                    • safely remove/eject the SD card from the PC
                    • put it back in the Duet, then start the Duet
                    • send M997 S1 from YAT to install it, and check that it reports success
                    • send M552 S0. It should respond "WiFi module is idle" after a few seconds.
                    • then you can try sending the M587 command again from YAT to set your access point SSID and password.
                      IanWalton
                      did as you asked
                      M997 reported successful upload.
                      M552 S0 does not respond
                        After sending M552 S0, please wait a few seconds, then run M122 and post the result here.
                        PS - also try sending M552 S-1 before the M552 S0.
                          IanWalton
                          M552 S-1returns ''WiFi module stopped''
                          M552 S0 returns nothing
                          M122 returns
                          Used output buffers: 1 of 32 (9 max)
                          Stack ram used: 3576 current, 4720 maximum
                          Never used ram: 7568
                          Last reset 01:20:22 ago, cause: reset button or watchdog
                          Error status: 0
                          MCU temperature: min 31.9, current 32.0, max 32.5
                          Slowest main loop (seconds): 0.099909; fastest: 0.000050
                          Segments left: 0
                          === Network ===
                          • WiFi -
                            === Expansion ===
                            IanWalton
                            i did a M122 after the S-1 and the only difference i could see was ''network state is disabled''
                              I am beginning to suspect that your WiFi module is faulty because the "Network state is starting" state should not persist. But first, another test please. Do you have a M552 command in config.g? If so:
                              • remove it or comment it out
                              • restart the Duet, wait a few seconds, run M122 and post the result here
                              • send M552 S0, wait a few seconds, run M122 and post the result here.
                                IanWalton
                                you can see whats in my config.g file further up.
                                i commented out all the network stuff, rebooted and the wifi led didnt flash
                                first m122
                                Stack ram used: 3576 current, 4504 maximum
                                Never used ram: 7784
                                Last reset 00:00:41 ago, cause: software
                                Last software reset time unknown, reason: User, spinning module GCodes, available RAM 7784 bytes (slot 0)
                                Error status: 0
                                MCU temperature: min 31.3, current 31.4, max 31.8
                                Slowest main loop (seconds): 0.000153; fastest: 0.000049
                                Segments left: 0
                                === Network ===
                                • WiFi -
                                  Network state is disabled
                                  Failed messages: pending 2779096485, notready 2779096485, noresp 2779096485
                                  === Expansion ===
                                sent m552 s0, no reply on yat
                                M122 returns
                                Stack ram used: 3576 current, 4664 maximum
                                Never used ram: 7624
                                Last reset 00:02:15 ago, cause: software
                                Error status: 0
                                MCU temperature: min 31.1, current 31.9, max 31.9
                                Slowest main loop (seconds): 0.099142; fastest: 0.000049
                                Segments left: 0
                                === Network ===
                                • WiFi -
                                  === Expansion ===
