    duet wifi connection issues
    Firmware installation
    2.4k
    • IanWaltonundefined
      IanWalton @ayudtee
      @ayudtee it does exist there, i updated it in an external sd reader, reinstalled it in the duet board and tried running it.
      came back
      Warning: Macro file /macros/SetNetwork not found.
        IanWalton @dc42
        SENDING:M122
        Used output buffers: 1 of 32 (1 max)
        RepRapFirmware for Duet 2 WiFi/Ethernet version 1.21 running on Duet WiFi 1.02 or later
        Board ID: 08DDM-9FAM2-LW4S4-6J1D8-3SD6R-T3SZX
        Static ram used: 16152
        Dynamic ram used: 100448
        Recycled dynamic ram: 2184
        Stack ram used: 3576 current, 4528 maximum
        Never used ram: 7760
        Last reset 00:00:21 ago, cause: software
        Last software reset time unknown, reason: User, spinning module GCodes, available RAM 7864 bytes (slot 3)
        Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0441f000, BFAR 0xe000ed38, SP 0xffffffff
        Error status: 0
        Free file entries: 10
        SD card longest block write time: 0.0ms
        MCU temperature: min 31.6, current 31.9, max 32.0
        Supply voltage: min 12.2, current 12.3, max 12.3, under voltage events: 0, over voltage events: 0
        Slowest main loop (seconds): 0.000259; fastest: 0.000049
        MaxReps: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
        Bed compensation in use: none
        Segments left: 0
        Movement lock held by null
        http is idle in state(s) 0
        telnet is idle in state(s) 0
        file is idle in state(s) 0
        serial is ready with "M122" in state(s) 0
        aux is idle in state(s) 0
        daemon is idle in state(s) 0
        queue is idle in state(s) 0
        Code queue is empty.
        === Network ===
        HTTP sessions: 0 of 8
        • WiFi -
          Network state is starting
          WiFi module is disabled
          === Expansion ===
        network state is starting
        wifi module is disabled
        hmmm, ive got a spare sd card somewhere, going to try reformatting it and starting fresh
          IanWalton @ayudtee
          @ayudtee
          sigh, im a dumbass, macro wasnt correct name, but, i corrected it and got it to run
          hasnt changed anything though 😞
            IanWalton @dc42
            config file contents
            ; Configuration file for Duet WiFi ver 1.
            M555 P1 ; Set firmware to look like RepRapFirmare
            M550 PCR10 ; Set machine name
            M552 S1 ; Enable network
            M587 S"PLUSNET-Q6QW" P"xxxxxxxx" ; access point
            M350 X16 Y16 Z16 E16 I1 ; Configure microstepping
            M92 X80 Y80 Z4000 E420 ; Set steps per mm
            M566 X900 Y900 Z12 E120 ; Set maximum speed changes
            M203 X6000 Y6000 Z180 E1200 ; Set maximum speeds
            M201 X500 Y20 Z250 E250 ; Set accelerations
            M906 X800 Y800 Z800 E800 I30 ; Set motor currents (mA)
            M84 S30 ; Set idle timeout
            M208 X300 Y300 Z400 S0 ; Set axis maxima
            M574 Y2 S1 ; Set active high endstops
            M574 X1 Z1 S2 ; Set endstops controlled by probe
            M558 P1 H5 F120 T6000 ; Set Z probe type to unmodulated and the dive height + speeds
            G31 P500 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
            M557 X45:275 Y45:275 S20 ; Define mesh grid
            M305 P1 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 1
            M106 P0 S0.3 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
            M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
            M106 P2 S1 I0 F500 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
            M563 P0 D0 H1 ; Define tool 0
            ; Automatic power saving
            M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
            ;M501 ; Load saved parameters from non-volatile memory
              @ianwalton said in duet wifi connection issues:
              WiFi -
              That bit suggests either an incomplete wifi firmware installation or an incompatible wifi firmware version. I suggest you do this:
              • download DuetWiFiServer.bin again from https://github.com/dc42/RepRapFirmware/releases/tag/1.21
              • use a PC to copy it into /sys on the SD card
              • safely remove/eject the SD card from the PC
              • put it back in the Duet, then start the Duet
              • send M997 S1 from YAT to install it, and check that it reports success
              • send M552 S0. It should respond "WiFi module is idle" after a few seconds.
              • then you can try sending the M587 command again from YAT to set your access point SSID and password.
                IanWalton
                did as you asked
                M997 reported successful upload.
                M552 S0 does not respond
                  After sending M552 S0, please wait a few seconds, then run M122 and post the result here.
                  PS - also try sending M552 S-1 before the M552 S0.
                    IanWalton
                    M552 S-1returns ''WiFi module stopped''
                    M552 S0 returns nothing
                    M122 returns
                    Used output buffers: 1 of 32 (9 max)
                    Stack ram used: 3576 current, 4720 maximum
                    Never used ram: 7568
                    Last reset 01:20:22 ago, cause: reset button or watchdog
                    Error status: 0
                    MCU temperature: min 31.9, current 32.0, max 32.5
                    Slowest main loop (seconds): 0.099909; fastest: 0.000050
                    Segments left: 0
                    === Network ===
                    • WiFi -
                      === Expansion ===
                      IanWalton
                      i did a M122 after the S-1 and the only difference i could see was ''network state is disabled''
                        I am beginning to suspect that your WiFi module is faulty because the "Network state is starting" state should not persist. But first, another test please. Do you have a M552 command in config.g? If so:
                        • remove it or comment it out
                        • restart the Duet, wait a few seconds, run M122 and post the result here
                        • send M552 S0, wait a few seconds, run M122 and post the result here.
                          IanWalton
                          you can see whats in my config.g file further up.
                          i commented out all the network stuff, rebooted and the wifi led didnt flash
                          first m122
                          Dynamic ram used: 100248
                          Recycled dynamic ram: 2384
                          Stack ram used: 3576 current, 4504 maximum
                          Never used ram: 7784
                          Last reset 00:00:41 ago, cause: software
                          Last software reset time unknown, reason: User, spinning module GCodes, available RAM 7784 bytes (slot 0)
                          Error status: 0
                          MCU temperature: min 31.3, current 31.4, max 31.8
                          Supply voltage: min 12.2, current 12.2, max 12.3, under voltage events: 0, over voltage events: 0
                          Slowest main loop (seconds): 0.000153; fastest: 0.000049
                          Segments left: 0
                          === Network ===
                          • WiFi -
                            Network state is disabled
                            Failed messages: pending 2779096485, notready 2779096485, noresp 2779096485
                            === Expansion ===
                          sent m552 s0, no reply on yat
                          M122 returns
                          Stack ram used: 3576 current, 4664 maximum
                          Never used ram: 7624
                          Last reset 00:02:15 ago, cause: software
                          Error status: 0
                          MCU temperature: min 31.1, current 31.9, max 31.9
                          Slowest main loop (seconds): 0.099142; fastest: 0.000049
                          Segments left: 0
                          === Network ===
                          • WiFi -
                            === Expansion ===
