    M500 dont work?
    • mickey30mundefined
      mickey30m
      Hi there,
      i have a problem with leveling my Z.
      i do this to level the Z
      M561
      M208 S1 Z-3
      G1 Z1
      then move the nozzle 3 steps down
      G92 Z0 because it needs more down
      move 2 more steps down
      then the nozzle is a paper thick from my bed.
      M500 to save it
      then G30 S-1 to see if it works
      and then it goes the same as when i start
      i have a config_overide.g but there is no code that related to this only my pid tune
        M500 only saves parameters that are determined automatically, for example by tuning and auto calibration. It used to save the G31 Z probe trigger height value too, but we removed that by default because it was confusing too many users. So you need to measure the Z probe trigger height and edit that value into the G31 command in config.g using the System Editor page of DWC.
        mickey30mundefined 1 Reply Last reply Reply Quote 0
          mickey30m @dc42
          @dc42 the trigger height i already put there, sorry i forgot to say
          G31 P25 X-10 Y-50 Z-2.332 ; Z probe trigger value, offset in relation to nozzle.
            dc42 administrators @mickey30m
            @mickey30m said in M5000 dont work?:
            A trigger height of Z-2.332 doesn't make sense because it means that the probe triggers when the nozzle is 2.332mm below the bed surface.
              mickey30m @dc42
              @dc42 so it needs a postive value?
                Yes, except for nozzle-to-bed contact sensors.
                  mickey30m @dc42
                  @dc42 many thanks, i think i get it now
