Low print quality Anycubic i3 Mega with Duet Wifi
4.5k
    newyork347
    Hello, I'm having low print quality after I upgraded Anycubic i3 Mega to Duet Wifi. On photos: bigger part was printed with original Trigorila and smaller part with Duet Wifi. What could be a problem?
    2_1527720815711_IMG_2538.JPG 1_1527720815710_IMG_2536.JPG 0_1527720815709_IMG_2534.JPG
    undefined 1 Reply Last reply 30 May 2018, 23:44 Reply Quote 0
      rbjam83 @newyork347
      @newyork347 It looks similar to the issue that I'm having. I posted about it here: https://forum.duet3d.com/topic/5490/strange-moire-like-texture-on-prints
      Are you using a Titan Aero by any chance?
      Is your extruder motor 0.9 degrees?
        newyork347
        All hardware is original (except Duet wifi), planing to do further upgrades after resolve this problem. Extruders are 1.8 degrees.
          newyork347
          Just few more photos
          1_1527725257400_IMG_2547.JPG 0_1527725257400_IMG_2546.JPG 0_1527725239992_IMG_2545.JPG 0_1527725223387_IMG_2544.JPG 0_1527725289631_IMG_2547.JPG
            newyork347
            This post is deleted!
              newyork347
              Thats my configuration
              12_1527727326707_tpre0.g 11_1527727326707_tpost0.g 10_1527727326706_tfree0.g 9_1527727326706_stop.g 8_1527727326706_sleep.g 7_1527727326706_resume.g 6_1527727326706_pause.g 5_1527727326706_homez.g 4_1527727326706_homey.g 3_1527727326705_homex.g 2_1527727326705_homeall.g 1_1527727326705_config.g 0_1527727326705_bed.g
                BPisLife
                I will look closer in a little bit but you currents are quite high. Try reducing them to 800mA. You don’t need to max them based on what their max capability but rather what you need. Also acceleration and Jerk should also be reduced as the default values tend to be high.
                  bartolomeus
                  In addition to the reply above:
                  • Looks like you have not pid tuned the hotend and bed (missing config-override)
                  • Max temp of 280 is too high for the stock hotend (PTFE throat)
                  • Set max acceleration on X,Y to 1000 and make sure your belts are tight
                  • Set max speed on X,Y to 9000
                  • Reduce your extruder acceleration
                    newyork347
                    bartolomeus, BPisLife, Thank You for your help, I did it but it didn't fixed issue.
                    2_1527780008900_IMG_2552.JPG 1_1527780008899_IMG_2551.JPG 0_1527780008899_IMG_2550.JPG
                      BPisLife
                      Can you post the config file again? Have you calibrated the extruder?
                        BPisLife
                        By the way, if you let the printer run with the web interface going, does the temperature look flat over a long period of time (say 30 minutes) or is it all over the place?
                        undefined 1 Reply Last reply 31 May 2018, 18:34 Reply Quote 0
                          newyork347 @BPisLife
                          @bpislife said in Low print quality Anycubic i3 Mega with Duet Wifi:
                          I played with settings, still no luck, temperature is alway is same in browser. I suspect that problem could be with extruder, in this print it uses 3 lines to build side wall when it builds 3rd line(facing inside of part that I'm printing) extruder making some different noise, but not extruding. Same happens for next layer. Thats how curvy lines appear from inside. I'm really sure that extruder in working conditions, something with settings. Thanks for helping!
                          12_1527791635501_tpre0.g 11_1527791635501_tpost0.g 10_1527791635500_tfree0.g 9_1527791635500_stop.g 8_1527791635500_sleep.g 7_1527791635500_resume.g 6_1527791635500_pause.g 5_1527791635500_homez.g 4_1527791635499_homey.g 3_1527791635499_homex.g 2_1527791635499_homeall.g 1_1527791635499_config.g 0_1527791635498_bed.g
                            BPisLife
                            Ok, now we are getting somewhere. Can you also post your gcode for that file. Which slicer are you using? Also, I would bring your extruder current down to 1000. Its better to run the motors lower as it keeps them from getting too hot.
                            When you say same thing happens for the next layer, do you mean for all walls or only inside wall it seems to have an issue? Which extruder are you using?
                              bartolomeus
                              Extruder acceleration is still very high.
                              Have you selected relative extruder in the slicer? And reprap flavour?
                                newyork347
                                I'm using Cura, Will reduce current to 1000. Problem only happens to inside side of wall. I'm Using extruder that came with printer, it looks like it have that stepper motor http://www.steppermotorshop.com/anycubic-nema-17-stepper-motor-bipolar-1-5a-40ncm57-1oz-in-4-leads-for-3d-printer-or-cnc-parts/
                                I will upload gcode
                                  bartolomeus
                                  Also reduce your extruder acceleration.
                                  Download and install the latest Cura. There is a i3 Mega profile already bundled in Cura. Make sure you set gcode flavour to reprap and set the extruder to relative mode
                                    newyork347
                                    @bartolomeus said in Low print quality Anycubic i3 Mega with Duet Wifi:
                                    I have latest Cura with anycubic i3 profile, changed to reprap. Here is link to gcode https://drive.google.com/file/d/1yMk5IfvMBrTtCwyZ7EYB5OR-yhmC-Qoa/view?usp=sharing
                                      BPisLife
                                      Out of curiousity what happens if you print with two walls? To me it sounds like a slicer issue but I don't know. What is strange to me is that the g-code only references "wall-outer" and never wall-Inner until very late in the print. I am not sure that means anything as I use simplify3d and its been a long time since I used CURA. As @bartolomeus said, make sure you set the extruder to relative.
                                      undefined 1 Reply Last reply 1 Jun 2018, 01:24 Reply Quote 0
                                        I will try to print two walls and will use slic3r too. I created second topic https://forum.duet3d.com/topic/5504/having-issue-printing-walls-with-duet-3d
                                          BPisLife
                                          Take a look at this post. Seems to be a similar issue.
                                          https://forum.duet3d.com/topic/5490/strange-moire-like-texture-on-prints-solved/27
                                          undefined 1 Reply Last reply 2 Jun 2018, 00:37 Reply Quote 0
                                          2 out of 24
