    Having issue printing walls with Duet 3D
    • newyork347undefined
      newyork347
      0_1527804843422_IMG_2560.JPG 2_1527804808073_IMG_2555.JPG 1_1527804808073_IMG_2552.JPG 0_1527804808073_IMG_2551.JPG 3_1527804766085_IMG_2559.JPG 2_1527804766084_IMG_2558.JPG 1_1527804766084_IMG_2557.JPG 0_1527804766084_IMG_2556.JPG Hello,
      I upgraded mainboard on Anycubic I3 Mega to Duet WIFI (everything else is original).
      I'm having an issue printing part with 1.2 and 1mm thick wall(maybe other sizes too), for some reason.
      With original Trigorilla mainboard there was no problem to print any size of walls. I attached D shape part, bigger one printed on Trigorilla and smaller one on Duet WIFI
      I also printed cube with Trigorilla and Duet WIFI - they look same. What could be a problem ? I opened different topic, but I'm thinking problem could be with something, https://forum.duet3d.com/topic/5493/low-print-quality-anycubic-i3-mega-with-duet-wifi
      I'm Using Cura on Mac
        It could be due to a difference in temperature calibration. What filament are you printing? Have you tried adjusting the extrusion temperature?
        • DADIYundefined
          DADIY
          @newyork347 said in Having issue printing walls with Duet 3D:
          There's a bug in the current version of Slic3r that causes this pattern, they say its to do with printing the inner and outer walls at different speeds with different cooling, maybe the same could apply to your Cura settings.
          More discussions about the Slic3r issue can be found here -
          https://github.com/prusa3d/Slic3r/issues/841
          porlock created this issue in prusa3d/Slic3r
          open underexrusion patern on wals #841
